Probably been asked a few times so TIA but would anyone know why it won’t make sounds or indicators flash when locking but will make sound and indicators flash when unlocking? Was working 2 days ago but now nothing. I’ve tried to find something in the owner manual but I can’t find anything. I’m fairly sure I checked the right fuses. They all seem fine. 2012,150 altitude. Any advice would be great.
Smart entry system
Those feature are part of the Customizations covered in Section 6-2 of your operator manual (your looking at Operation signal (buzzer) and Operation signal (emergency flasher) on around page 269).
The strange thing in your case is these are a volume control OFF- 7 levels and on/off for both lock and unlock so it appears your ECU for some reason is not following the settings for one of the cases.
Maybe try turning both customizations to OFF and see if it does this and then back to ON and see if that fixes the glitch.
Maybe it is seeing a door or possibly window not shut properly, check door switches and windows.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
