ARB tyre inflator + pressure gauge + chuck
SGS, Thanks for that. Will look at getting some.
SOL.[COLOR="#006400"][url]http://www.pradopoint.com/showthread.php?26339-SOL-s-150-shorty-SX[/url][/COLOR]
Got one of these. Close to accurate. Reads 40psi when it's 38psi.
AJ[i][size=2][color=#008000]2008 D4D GXL Auto [/color]- [u]BLACK[/u][/size]
[size=2][color=#0000FF]- ARB Deluxe Bullbar - TJM Airtek Snorkel - Pirhana Dual Battery - BFG A/T's - Waeco 60L - Canvas Seat Covers - LED Spotties - Bilstein/Ridepro Lift - TJM Bashplate - GME TX3440 UHF - Rhino Roof Bars - Rooftop Tent & Awning - Poly-Airbags - ScanGauge II - Beaudesert 2.75" Exhaust - ARB Twin Motor Compressor [/color][/size][/i]
We did a comparison of these on the GTG at beachport. I think we tried 2 or 3 of these gauges and they were wrong, by 4 - 7 psi. We made this comparison against a number of normal gauges that all read the same PSI (different brands too).
On another note, I'm on my third one of these ARB gauges since September. The first gauge didn't even go into the orange hose (found this out at the GTG and had to borrow one for the whole trip). The second replacement gauge has been used three times. The bleed valve on this one simply fell-out the other day whilst it was in my recovery bag. I'm going for the third one this week. Fingers crossed the third is okay.
BUY AUSTRALIAN! BUY BRAND NAMES! BUY QUALITY!
Pigs ass..........................................Diesel Prado with various things...
OK just had to do a little test.
Tested my standard tyre gauge (what you find at a servo but better quality) that was tested many years ago and was accurate, against ARB deflator and ARB tyre inflator + pressure gauge + chuck
Standard Tyre Gauge - 39.5 PSI
ARB deflator - 36.5
ARB tyre inflator + pressure gauge + chuck - 39.5
Seems so far the inaccurate one is the deflator and this was purchased in more recent times.
Will check all these against BP servo with stand alone unit and report.
HazzaSilver 120 Series Diesel GXL 2009 with Option Pack 2, king Springs 2" Lift with 'H' front spring, MT ATZ 4-RIB, Dual Battery, Deluxe ARB Bull-bar, Winch, Towbar, Anderson 50 amp plug at the rear, Weather Shields, Bonnet and Head Light Protectors, Rubber Mats inc Cargo mat, UHF Ariel, Portable Uniden UHF plugs into areal, On-board ARB Compressor, Brains Black Box TG150 Protector, Rear Black Duck Seat Covers.
[B]Black '09 150 D4D GXL[/B]. ARB Winch bar, OME 2"lift, ARB underbody protection, Rock Armour sliders, Runva 11XP Winch, ARB CKMA12 air Compressor, dual batteries, Optima 55ah battery, Safari Snorkel, WetSeat Covers, Outback Ideas Recovery Points, 17x8 Dynamic Wheels, BFG Muddies 265/70r17, Awesome home made rear draws with fridge box & ARB slide, KAON transfer &a actuator guard, ARB front & rear lockers,
What happens to the air pressure coming from the compressor when the lever is released? Does it release the air , or does it block the hose causing the pressure to back up to the compressor?Originally posted by VXWesty View PostThey've been around for nearly two years, and yes, I have one that I use on an ARB compressor. I've not checked for accuracy but it seems to be good.
i find it a very useful tool as I can air up (or down) and check pressures very quickly. The pressure reading only shows when you release the lever - while filling it shows 0.
VXWesty
I'm not sure if my compressor will automatically cut off, so just wondering if I would cause any damage by using one of these?
thanks.
Compressor stops immediately & will start up again with lever or be released when you disconnect the hose.
Mine was reading 10psi too low so swapped it over worries
Sent from my SM-J110F using Tapatalk2008 120 GX D4D with a few extras
Rig build here
Depends on the compressor you have. I think all the current ARB models have a pressure cut off switch but with some of the older ones it was an optional extra.Originally posted by stretch2k16 View PostWhat happens to the air pressure coming from the compressor when the lever is released? Does it release the air , or does it block the hose causing the pressure to back up to the compressor?
thanks.2009 120 GXL D4D, TJM Bull Bar, Winch, Safari Snorkel, ARB Lift, ARB Lockers, Black Widow Drawers
I placed a loose medium thickness cable tie that I can slip over the leaver so I too can walk away while it is filling and it is loose enough to slip back off when you want to stop filling.Originally posted by AJ120 View PostSeen plenty of guys using them, Dodgy Dave had one that was reading 6psi low, ARB replaced it for him. Personally I just prefer my standard clip on air chuck, I can wander around whilst reinflating without the need to stay squatted down to hold the trigger.
Cheers Andrew2009 120 GXL D4D, TJM Bull Bar, Winch, Safari Snorkel, ARB Lift, ARB Lockers, Black Widow Drawers
