The install was done was as part of the swap out of the existing head unit by the installer. I put in a Toyota head unit that came out of 86 Toyota
Dual USB charging ports to replace switch blanks
Gday,
Can anyone who has a 120 comment whether their dual usb point they purchased and have installed has a background light on when the car ignition is on.
It appears from other comments the points for the 150 do have a blue light.
I've purchased one off ebay as well and if it does then I will purchase a switch so the point is not live when not in use.
Leon08 GXL 120 D4D 5 Spd Auto - Option Pack.
ARB Deluxe bar, Safari Snorkle, Icon Suspension, Milford C/B, Scangauge2, Sandgrabba Mats, AMTS - Recovery Points/Radiator Plate/Rear Carrier Spacer, Redarc dual battery system, Icom 400 CB
This is the Air On Board version for the 150. I haven't installed it yet, but just noticed there is a blue light within the USB sockets. Don't know why they put lights in at all. It does however have a cover so both ports/lights can be covered when not in use.
2014 150 GXL D4D Facelift, White with Colour Coded ARB Deluxe Bar, Side Rails and Steps, ARB Recovery Point, ARB Intensities (1 x Flood, 1 x Spot), ARB Air Compressor on AMTS bracket, ARB 60L Fridge, OME 2” Lift, BFG AT2 265/70/R17, Dual Battery with RedArc SBI12, HR Tow Bar, Sandgrabba floor mats, Pioneer Platform, Outback Drawers, MaxTrax on TraxRax, Icom IC-450N UHF, The Wet Seat seat covers, AMTS tyre carrier spacer and telescopic light pole.
Originally posted by Leon H View PostCan anyone who has a 120 comment whether their dual usb point they purchased and have installed has a background light on when the car ignition is on.
Thanks guys,
I reckon I'll buy another switch to minimise the power draw when it's not being used.
Thanks again08 GXL 120 D4D 5 Spd Auto - Option Pack.
Originally posted by Leon H View PostI reckon I'll buy another switch to minimise the power draw when it's not being used.
Correct me if i'm wrong, but I see no reason why you can't be rid of the harness connector it comes with, and up the power for each USB output independently. As long as you fuse each one with say 2Amps, you should be fine. I haven't personally seen the cable though, so can't say for sure whether it's rated high enough?Diesel Prado with various things...
Originally posted by iantz View PostCorrect me if i'm wrong, but I see no reason why you can't be rid of the harness connector it comes with, and up the power for each USB output independently. As long as you fuse each one with say 2Amps, you should be fine. I haven't personally seen the cable though, so can't say for sure whether it's rated high enough?
its not about the external wiring, there will be a DC-DC converter inside that converts the 12-14v of the car, down to 5v, and it is the current limit of this circuit that restricts it to 2.1A, but the fact they are wired as 2 individual outlets I would suspect they're 2.1A each, can you confirm this yet Andrew?Last edited by waltec; 20-03-2015, 09:06 PM.2003 Prado Grande TD Auto Pearl White
I have 2x Nexus 7 and a Motorola Moto G for testing. I used a Watt Meter to get the power readings on the 12V side. A Projecta IC700 charger was used as the power source. Its output is 13.74V.
If I only plug in 1 device to any of the ports on the charger, I get a reading of 8.3W (1.66A @ 5V).
If I plug in 2 devices, I get 16.7W (3.34A @ 5V)
I need to get an ipad now to check if one charging port can deliver 2.1A.Last edited by amts; 21-03-2015, 12:27 PM.
Originally posted by amts View PostI have 2x Nexus 7 and a Motorola Moto G for testing. I used a Watt Meter to get the power readings on the 12V side. A Projecta IC700 charger was used as the power source. Its output is 13.74V.
[ATTACH=CONFIG]19384[/ATTACH] [ATTACH=CONFIG]19385[/ATTACH]
[ATTACH=CONFIG]19386[/ATTACH]
Conclusion: Each port is the same and is limited to 8.3W or 1.66A each.
Next is to repeat the same test for the 150 version.
