Prado Rim Size & Offset Database
This is a sticky topic.
  • FJ rims are 7.5" wide.
      Yeah your right, brain fart here. They are just about the ideal size an offset, pity I don't like them
      Yes talking about the factory ones.
      AJ120
      Out of control poster!
      • I didn't like the old FJ rims but the new ones really suit the 150. If someone offered me 8 I would jump at it. For the right price of course!
        mjrandom
        Last edited by mjrandom; 15-12-2014, 09:21 PM. Reason: Oops forget about the $$$$$$$$
        • Hi!
          Need some help here.. I thought of getting Ballistic Jester wheels to my 120 Prado. Wheel size would be 17x9" and tires maybe 265/70 r17. Does anyone know, what would be the right choice for the ET (offset options for that wheel is +12, 0 or -12)??
          One of this Forum member had those same wheels on his prado, and they looked really nice..but I don't know the offset..
          Asked for this same question in this topic:
          http://www.pradopoint.com/showthread...orwegian-LC120
          Those wheels:
          http://www.jegs.com/i/Prestige-Autot...ductId=2797698
          I have original suspension at the moment..maybe some lifting in future, if needed..
          Thanks!
          • If it was only those 3 choices, then +12 is the one you want. Just that it is too much increase in track to be legal. The other 2 offsets is not advisable. The factory rims is also fine for 265/70R17.
            • R-2 what are you rules about modifying track in Finland? Here it is typically maximum +25 -0 though there are variations which allow +50.
              • Thanks a lot for answers!
                Rules about modifying rims and tires in Finland:
                1) ''The rims exchange as a result of a car each axle track width may change up to 30 mm compared to the original''
                2) Modification inspection must be done by traffic authority if:
                a) The rim diameter differs from the original more than 26 mm
                b) Tire width differs from the original more than 30 mm
                3. The tire's outer diameter must not be increased by more than 51 mm and width of more than 102 mm from the original.
                Sorry for my limited english know-how..
                • Sorry I can't see your location when I'm posting from the phone.
                  To meet the 30mm track increase in Finland, then you can only go to +15 offset. +12 is 36mm increase in track.
                  • Yep!
                    I made a same conclusion, but I think that would not be a major problem..
                    Thanks!
                      I was surprised when I checked the back side (new style FJ rims) and found big sign CHINA...
                      Prado [I]Grande[/I] 4.0
                      • Is anyone know weight of 120 / 150 / FJ rims?
                        • Just wondering..
                          I have Binno B 2060 HP 18X8,5" wheels, ET 0. http://www.binno.com/index_ingles.htm
                          I thought of getting 275/65 r18 Hankook Dynapro MT RT03 tires to my Land Cruiser 120. Will they fit properly without any rubbing? I have original suspension and no lifting. http://www.amazon.com/Hankook-DynaPr.../dp/B004QL69CC
                          Would it be better option to get 265/65 r18 BF Goodrich All-Terrain tires instead? http://www.amazon.com/LT265-65-18-Go...es+265%2F65+18
                          I have read a few topics about this..some say those tires fit, some say they will rub a little..Does anyone have own experience?
                          Thanks!
                          • R-2 cannot say precisely but use this:
                            http://www.rimsntires.com/specspro.jsp
                            To compare sizes. What you suggest is a bit bigger than 265/70 17 and a bit smaller than 285/70 17. The extra offset out will be the issue and these may run on the guards.
                            I will let someone with better knowledge jump in. Nice wheels by the way.
                            • Guys,
                              if anyone can give me some idea where to find weight/size chart of TRD rims for HiLux/Prado/FJ that would be great. Thanks.
                              • The three or four cast Toyota 17" wheels that have been weighed are all around the 20kg mark if I recall correctly. Unless a wheel is forged it isn't going to vary much and none of the Toyota wheels are forged that I know of. The weights for some wheels are listed in the database.
