Prado Rim Size & Offset Database
This is a sticky topic.
Job done
I abandoned the idea of finding fancy chrome caps as I couldn't get any to fit and once I've given the stub-axle caps a spray of silver it'll look good as new. Might even go mad and give the whole hub a spray. Better than the crappy chrome things. They should be water tight anyway.
I was going to change the studs but opted to use Ford nuts to suit the existing studs and slid a couple of washers onto the collar of Ford nuts in lieu of the flange on the Prado nuts
Thanks everyone, esp amts for your advice and input. For the first time, I have interchangeable wheels. - albeit not perfectly matched but close enough to keep me going.
I need to change the van studs to match the Prado nuts thread and then I can use the Prado nuts. Either that, or just use some chrome Speedy ones. Looks like I'll have to use those chrome caps too as the stub axle intrudes too much to use the Prado caps. Constant maintenance to keep em from rusting though. Can't do much right now as I've buggered my shoulder for a couple of weeks. I guess I'm in for a bit more googling to find alloy nuts and caps.
Leave a comment:
Guest repliedPost some pics
Leave a comment:
Got the set last week
Axle stub intrudes a bit so will have to get a deep cap to accommodate. Those speedy ones rust as soon as you look at them. Just have to keep on top of it. Otherwise, just the job.
Leave a comment:
Thanks for your help pal - you're a legend. I'll have a look at those later this week.
Leave a comment:
Guest repliedYes they are. The front face of the rim has a slightly different pattern to the GXL rim.
Leave a comment:
Thanks for that, mate.
So, they are the 6.5" ? I didn't recognise that by the description.
Much appreciated.
Leave a comment:
Guest repliedHere are some rims with tyres, although the tyres would need to be checked if they are still within "date".
WA - http://www.gumtree.com.au/s-ad/welsh...els/1124747450
NSW - http://www.gumtree.com.au/s-ad/galst...-x4/1124731318
Leave a comment:
Leave a comment:
Guest repliedSaw at least 6 listings on Gumtree. Depends on where you are.
Dealer will charge you 1 for the price of a second hand set.
Leave a comment:
Ha
Solving the problem is one thing but try finding the bloody things. Had a bit of a Google and been thru speedy wheels and the like but no joy. Might give the local dealer a bell in the morning and see if they can get them in.
Leave a comment:
Thanks fellas.
Looks like the GX 6.5" are the answer - as long as they'll be ok on front or back to get me to a tyre shop - which, of course, could be 400 kms away
Leave a comment:
Originally posted by Cloud View PostSo p10 would give me 20 mm clearance on the van, which is good. Could I use one of those on the car with the standard 265/65/17 on the other side, (front or rear?) if I do my spare on the car and is it ok front and rear, bearing in mind the cars independent suspension?
Leave a comment:
Guest repliedOriginally posted by Cloud View PostYes I am.
Would those be the 6" rims?
Leave a comment:
Guest
Guest
Guest
Guest
Guest
Leave a comment:
