Camper trailer water filter
  • Camper trailer water filter
    Hi all
    I am thinking about a water filter to assist with cleaning water for drinking. My trailer has a 60 litre tank and I would like to add a filter.
    Would it be best to just use a filter in line with the hose on filling? or is there any options to add one inside the trailer to filter it as it comes out of the tank? or both?
    Looking for some adivce and in particular what other people have setup.
    Andrew
    2005 VX Diesel - [URL="http://www.pradopoint.com/viewtopic.php?f=38&t=12823"]My Rig Buildup[/URL]
    [URL="http://www.fuelly.com/smallsig-metric/65233.png"][img]http://www.fuelly.com/smallsig-metric/65233.png[/URL][/img]
    [B]Bitumen - A blantant waste of taxpayers money![/B]
    [URL="http://www.pradopoint.com/viewtopic.php?f=38&t=12197&start=0&st=0&sk=t&sd=d"][/URL]
    I've go to get one of these as well. Was going to get the one that clips onto the hose. I think BCF sell them.
      We use a domestic type water filter cartridge (Same as "Pura Tap" etc) it's a single cartridge type and we use a combination particle/charcoal filter in it.
      It's fitted between the tank and hand pump.
      Mick
        Not sure what you are willing to pay but I have a system from these guys installed at my house (tank water only) and I have noticed they do a system for caravans.
        http://www.psifilters.com.au/47-caravan-systems
        Peter is a good guy to talk with about water filtration systems. No affiliation... just a happy customer.
          thanks all, I was thinking about one of those units from bunnings (similar to Pura Tap) and putting it between the tank and taps.
          Keep the ideas coming.
          Andrew
            Andrew,
            Have put on an inline filter in between the tank and the pump on my camper trailer, I got the filter from BCF for $40 - $50. Assumming you have a 20 - 25mm filler hose on your tank, you couldnt put this one prior to the tank as it is suited for 12mm. Besides, if you did get one on to fit it would take you forever to fill up your tank. With mine it has slowed the hand pump up slightly, but it is a small price to pay, nothing worse than having to boil your water each time.
            2005 GXL, TJM Bar, 2" Tough Dogs, Narva Spots, GME UHF Radio, Warn Winch, BFG AT's, Dual Battery, Red Arc BMS, Safari Snorkel, ARB air, Piranna Breathers, Rhino RR, Waeco 50lt, XTM recovery, Open Sky Awning - towing a Customerline Camper Trailer!
              This is what I use: http://www.bestwaterfilters.com.au/store/
              Leachy
              EX-Prado Owner
                The flowjet ones have survived for a few years in central australian conditions, mainly to keep out the big bits from water pumps, etc.
                http://www.caravansplus.com.au/catal...5443304e68feed
                Be selective of where you fill up and use a suitable potable hose & connection.
                Unless you are running a chemical or heat treating purification system the cleansing value of "filtering" the harmful stuff out is questionable and predominantly a sales pitch. i.e. everytime there is a municiple water quality alert - it is always recommended to boil your water.
                "Ooops I just deleted the internet, lucky I was able to recover 99.7% of it out of the bin" :lol:
