Originally posted by digoptions
If you tell us 1 in 50 is a dud, then add the likes of myself and Lippa, add those that have had issues that need to be worked through, and if you read the threads there are a lot with issues, then it is pretty clear that these units are at the junk end of the market. I don't mean to be harsh Matt as I know you try your best, i do however believe I should call it as I see it.
And in case you were wondering a different SD card doesn't make the slightest difference, every second funtion in Ozi still causes the unit to freeze and I have to reboot it in order to do anything.
