Plastic taste in camper water tank
  • Plastic taste in camper water tank
    Any quick solutions to getting rid of plastic taste in camper trailer water tank
    2004 GLX Prado 3ltr turbo deisel, Ironman winch bar, 9500 t-max winch, Ligthforce 240 blitz's,265/70/17 mickey T's MTZ's, powerful 4x4 roof rack, lightforce 170 strikers, 2" bilstein shocks - dobinson springs, outback roof console
    Try lemon essence with half cup of bicarbonate of soda, leave for couple hours, drain and flush. Then fill up tanks. Works a treat.
    Edit: meant to say add the lemon essence and bicarbonate with a full tank of water.
    150GXL 3.0D4D Auto, White, ARB Deluxe Winch Bar, iCom ic440 Pro UHF, Safari Snorkel, Rhino Bars and Platform Rack, Dual Battery System, Brown Davis underbody protection, Cooper ST MAXX Tyres, Lovells Springs & Shockers & 2" lift
      I will give that a try, sounds like an easy fix
        Check-out myswag.org it has a lot of info on this topic. Also make sure your lines aren't made of the wrong grade of plastic too.
        [B][SIZE=4]ntp
          Hi also on a empty tank put small bottle of vanilla essence into tank then full up leave 5-10 min then drain then put bottle lemonade into tank full with water leave 5-10min then drain works well
          Cheers Wayne
          2008 Prado GXL D4D Auto Silver, 265/70x17 Mickythompson ATZ 4 ribs, ARB delux Bar Avenger Mako 9500 winch, TJM XGS Gold suspension, Poly airs, Safari Snorkel, Dual Battery system, Voltage Booster, Lightforce XGT lights, GME TX3100 UHF,ARB CKMA12 Compressor, ENZD special quad breather kit,Outback Draw system 1/2 Cargo Barrier,Kaymar duel wheel carrier,AJ120 Sliders, Taipan XP Exhaust, Twin E Lockers, Foxwing, Pioneer Platform.
            Don't forget the obvious, don't fill the tank with ordinary garden hose!
              I remember when we once almost ran out of beer and almost had to drink the camper trailer tank water too. lol
              [B][SIZE=4]ntp
                thats what the tank under the ct is for to store beer in - why would some one want to put water in the tank ?
                  Close call ntp. One would be forgiven if they attended a few counselling sessions after such a stressful ordeal. My thoughts are with you mate.
                    I have heard of people filling about 1/4 of the tank and using a whole packet of denture cleaning tablets...
                    [b]2013 GXL LC200 TTV8[/b]
                    TJM Alloy Bullbar
                    Towing a Jayco Expanda 17.56-2OB
                      Tried everything to fix mine and nothing worked, then got some tank clean from the caravan place and hey presto all fixed.
                      Alan
                      [color=#0000BF](The MK II) 2012 GXL Auto Diesel, White, ARB Bull Bar, Warn 9500lb XDC Winch, ARB Alloy Roof Rack, Aussieoutdoordirect Awning, Toyota Tow Bar, Safari Snorkel, ORS Rear Drawers and Fridge Slide, ARB Battery System with REDARC isolator, ERPS 10 Pad electronic Rust Cont, 275/65/17 BFG AT's, Jumbuck Sheep Skin Seat Covers, REDARC EBRH Brake Controller, OME 2" lift kit, Air Bag Man high pressure air bags, ARB CKMA12 on board compressor.[/color]
                        Originally posted by Strider View Post
                        ... got some tank clean from the caravan place and hey presto all fixed...
                        Which probably contains Sodium Bi-Carbonate ?
                        Rob.
                        '08 GXL V6 Manual with: O/L Bar, Cibie Oscars, Safari Snorkel, Revalved Ironman 45710 Struts & 45682 Shocks, Dobinsons & King springs, MickeyT STZs, Eaton E-locker on rear, ScanGaugeII, InaWise TPMS, and a Tvan controlled via TowPro.
                          I tried lemon juice, bicarb soda, milton and vinegar to try and get rid of the terrible taste, all to no affect. Eventually I traced it to the food grade hose I bought from Bunnings. I think it was impregnated with its own chlorine source so everytime you filled up the water got treated for you.
                            Not sure Rob, I shared it with a mate and he still has the bottle.
                            This is the product. http://www.caravansplus.com.au/catal...oducts_id=5522
                            I tried Bi-carb but it did not work.
                            Alan.
                              [http://www.ehow.com/how_5848916_remo...er-cooler.html ]
                              This will help you.
                              [URL="http://www.dentimpressions.com/"]Paintless Dent Repair[/URL]
