Lexus V8 (1UZ) into Prado 90 V6
  • #31
    fark yeah, looks awsome , the charger idea is good but would cost nearly as much to bolt a supercharger on than do the 1uz conversion, and i think most people will be dissapointed by the superchargers performance considering cost to set up etc.
    • #32
      GREENVX, I sincerely hope I do not have to replace the drivebelt. There's only one, what is called a serpentine belt. Hopefully Crooza is correct, otherwise I'll remove the radiator first.
      I'll post all the pictures I can, but due the car being about 90 mins drive from my house, I cannot get there more often than once every weekend. This week I won't even have time for that, but the mechanic said he'll take pics. Next weekend the truck should come home.
      LouisF
      • #33
        Keeping an eye on this thread as my 90 1kz is a great engine but is using coolant (the old cracked head syndrome) and i have a 1uz at home which i am thinking of pulling out of my 280zx so please keep the info and pics coming.
        Chris
        96 SWB, fire engine red, turbo,auto,
        50mm king springs, tough dog shocks,
        13mm strut spacer, 17 x8inch wheels incubus poltergeist 17x8
        265x70x17 Kelly TSR, factory sunroof,
        Dual batteries, gme 3220 uhf, turbo timer
        , ipf extreme spots, cibie super oscar spreads converted to HID.
        Factory alloy bar, Safari snorkel,
        Table on rear door, Rear work light
        300watt inverter, high lift jack
        Wish List (winch and front air locker)
        • #34
          The transplant is complete bar some finishing-off still required. A pic or two of the engine in the car:
          All I can say is, if you drop the hammer, she's off like a bat out of hell: roaring engine, push in the back, nose up!
          Fuel usage still inconclusive. Did find 5.1km/l (14,5mpg), but I made some use of the extra oomph
          But what a rush to drop some unsuspecting guy in a car he had thought was quick.
          • #35
            More info please! eg: what had to be modified on the car and engine, is you car manual or auto? and more pics!! thanks in advance!
            75 Series Cruiser No More
            Replaced with a G6E Turbo
            95 Series Prado [url]http://www.pradopoint.com/showthread.php?19936-Beast2h-s-Prado[/url]
            • #36
              I think its an Auto, judging by the lack of a clutch master cylinder.
              • #37
                Ahhh! good eye's!
                • #38
                  Yes, an auto. The engine is too long for the engine bay in that one has to remove the viscous fan. Mine was replaced by a 16" electric fan (controlled from the ECU) mounted between the engine radiator and the A/C radiator. Two smaller fans are also mounted in front of the A/C radiator. The engine's ECU would obviously not work properly with the Toy 'box so that has been replaced by a locally produced one, a Spitronic. Very tuneable. The bell housing and torque converter have been replaced with Lexus units. At the moment the idling is set at 1 000r/min, which I believe is too high, for when coming to a standstill and taking off gently there is a sort of jerk before stopping completely and just when you start moving, but that may be a result of the high idling speed not working well with the torque converter's stalling speed, or something. It has to be reset at 700r/min and then we'll see if that is all that is required. The mechy wants to replace the 'box ECU also with Spitronic's TCU (transmission control unit) - at his own cost, would you believe it! - for then one can setup the shift pattern to your liking. Up to 3 programs can be loaded, each programmed from your laptop while on the move, and you choose the one you want for the road/traffic conditions. The shifts are almost super smooth at present, even better than I can remember it being before, even under hard acceleration.
                  When I searched the web for the weights of the V6 and of the V8, I could only find a post somewhere (can't remember where!) that says the V8 (aluminium block) is 60 kg lighter than the V6 (cast iron block). Be that as it may, there is no suspension sag to speak of up front. Front is slightly less than 10 mm (3/8") lower than rear, measuring the height of the wheel arch above the bottom edge of the rims (763mm rear and 757 front). I do not pretend that my measurement is 100% accurate, but you get the picture.
                  And that is about the extent of the modifications. Ah yes, the engine's sump has been replaced by a mild steel one fabricated in their workshop. Before I post anymore pics, I want the finishing off to be done to my taste. That is planned for the near future. And maybe I can do an acceleration run and see what she'll do from 0 to 100km/h (0 - 60mph, actually 62,5mph to be precise.)
                  LouisF
                  • #39
                    Thank you, how did you go with the engine mounts?
                    • #40
                      Wow! Looks great Louis. Well done. I'm keen to see how your fuel economy works out. Keep the pics coming if you can - there's some very keen Aussies watching this with envy!
                      Cheers, Ben.
                      • #41
                        The engine mounts were modified by the mechy who did the job. I'll ask him again, but IIRC he kept the mounts on the car and made a modification to fir the engine to the mounts, a steel bracket. I was not there at the time the engine was installed, but I'll see if I acn get pics of the mounts as they are now, or otherwise try and get pics at the shop next time I go there. The truck has to on the lift again and maybe one can get pics then. Maybe the mechy indeed took some pics as he had promised at the start.
                        I made a mistake with the measurements last night and will re-do those and report back. The truck has a decidely nose-down look that I can't recall from before. Maybe the pics I took shortly after I bought her and after pics now will show the diffirence clearly.
                        I filled her up last Saturday, first time since the swap, and the results showed 5.5 km/l (about 14.5 mpg) previously 5.6 - 6.0 km/l (15.9 - 17.0mpg), but that included a little more spirited driving than my usual style. I burn to see what she'll do on the trail, but that might have to wait a bit.
                        [Edit: Made a typo with fuel economy. Should be 5.1km/l (which is indeed 14.5mpg) and not 5.5 km/l. Sorry.]
                        LouisF
                        • #42
                          Checked the measurement again, and the difference between front and rear is 10mm (3/8") not much different from the previous post where I mentioned this. So the V8 does not have an effect on the height, after all, meaning the springs are OK for it.
                          LouisF
                          • #43
                            Here are two pics of the radiator setup, that shows why an electric fan is required.
                            [Click on image to enlarge]
                            • #44
                              WOW that IS TIGHT!
                              Are the fan(s) located on the front side?
                              • #45
                                I would be interested to see if that comes close to touching in rough conditions.
