Laboratory Oil Testing
    DOH! Double post!
    t303
      Originally posted by t303 View Post
      DOH! Double post!
      Go into "edit post" and find the delete post tab! If you do that I will delete this and everything is tidy again.
        This is the basic kind of readout you get from places like Cat.
        DETAILS
        Lab No Eval Date Sampled Date Received Label Actioned Meter Read Comp. Hours Fluid Hours Fluid Added Fluid Changed
        00922XXX A 11-Jun-2012 13-Jun-2012 A332XXX N 55300 55300 5300 0.00 Y
        ELEMENT TESTS
        Lab No Eval Fe Cr Cu Pb Sn Ni Al Si Mo Na K B Ca Zn P Mg H2O Fuel PQ
        00922XXX A 11 <1 1 <1 <1 <1 3 20 112 3 <1 4 3114 1263 1173 15 <0.1 NEG 1
        LUBRICANT TESTS
        Lab No Eval ST OXI NIT SUL AW AOX V100 V40 VI A
        00922XXX A 14 8 5 15 17.0 0.0 14.0 103.2 138 0
        COMMENTS
        Lab No Eval Comment
        00922XXX A As this is the first sample no trends are evident. Wear levels appear acceptable for hrs/km on oil. All other Test Results appear Acceptable. Continue Sampling at the Recommended Interval.
        2011 150series GXL
          Thanks for that. Very helpfull
          Malcom
          Prado 95 TX turbo diesel
          LC100 GXL turbo diesel
            I have a truck and trailer and I'd be interested in doing it on my 2010 FM480 Volvo because it's only due for a service every 30,000klms and not sure how good or bad it is for the truck considering it cost me nearly more than my house I want to look after it
            [COLOR="navy"]2005 GXL Prado, Bilstein Shockers, King Springs, IPF 900xs, Steel ARB Bullbar, 12000lbs winch, GME 3540 UHF, Weaco 50L & 38L, Dash mat, carpet and rubber Prado mats, awesome after market head unit BF Goodrich & more to come[/COLOR]
              DETAILS
              ELEMENT TESTS
              LUBRICANT TESTS
              COMMENTS
              Lab No Eval Comment
              mmm, thats more diffficult to understand than a Full Blood analaysis report from pathology...Red Blood Cells, Protein, Liver function tests, pH etc I can understand, but as for an oil analysis....now thats complicated
                It's present much better when you get your report, in a nice little table which makes it easier to read.
                heres a Cat document which doesn't really answer any questions but other might find it interesting:
                http://www.cat.com/cda/files/2518338/7/PEGJ0046-01.pdf
                2011 150series GXL
