I've just got a set of IPF 900XS lights. When I picked them up the guy in the shop opened the box, took out one light and said "this is the Spot and should go on the drivers side, the other is the spread beam".
That sounded fair enough so I took out the one he said was the spot and fitted it on the drivers side as recommended, I then took the other out and looking at it I can't see how he knew which was which - they both look the same to me and they both have 900YS on the glass.
I did try putting power on them but the beams look the same to me in daylight.
Can anyone tell me if I should be able to tell them apart or have I been given two the same?
