I have a "Seacured" combination lock. It is basically a combination lock with a place inside to put your keys. I use it while surfing. It attaches to your bullbar, tow bar, or recovery point. Works like a treat. It is big enough to place a full set of keys including transponder. No more worries about being seen hiding your keys. Costs about $50 and available from most "proper" surf shops. They are also available on the net in eBay. The perfect solution. Cheers
Spare Key best place to hide it.
I don't use these because they advertise where the keys are and that you are away from the vehicle. They also don't look that difficult to break open.Originally posted by Chatty View PostI have a "Seacured" combination lock. It is basically a combination lock with a place inside to put your keys. I use it while surfing. It attaches to your bullbar, tow bar, or recovery point. Works like a treat. It is big enough to place a full set of keys including transponder. No more worries about being seen hiding your keys. Costs about $50 and available from most "proper" surf shops. They are also available on the net in eBay. The perfect solution. Cheers[B]Steve[/B]
