ARB Air Fittings
  • #31
    Do you reckon the air fittings simple unscrews from the end of the hoses?
    Most do! Unless they are a crimp in which case there are no flats on the fitting!
    • #32
      Confirmed. The ARB air fittings have a male thread and screws into the end of the hose. Now to grab the SCA Blackridge hose.
      • #33
        The air fittings on the Blackridge hose are crimped on. It is also a bigger OD than the ARB orange hose.
        I took apart the ARB fittings and it isn't a simple screw off fitting. The attachment to the hose is a combination of a nipple/barb and a screw on clamp nut. I'm not sure what this thread is yet.
        Something like this
        Due to the difference in hose OD between the Blackridge and ARB, I can't simply shift the ARB fittings over as the hose ID may not be the same, but the clamp nut won't fit over the Blackridge hose as the OD is bigger.
        amts
        Ninja Poster.
