Next Accessory - What should it be?
  • #31
    There ya go Stan!
    Winch vote
    • #32
      The winch is winning. Go the winch, looks good if nothing else! :roll: :lol:
      Matt
      • #33
        Hey Stan,
        What did you end up with?
        Hopefully BOTH the Fox shocks and the Warn, I hope!! 8)
        • #34
          Hey Grandeman,
          Shocks has been sitting with Darren for last 3 months as I haven't had
          a time to get them fitted :shock: :roll: :roll:
          Hopefully will be fitted next week with a winch coming later on :wink:
          [color=blue][url=http://www.pradopoint.com/showthread.php?12128-2004-120-GXL-V6-Petrol-Buildup-*Warning-Picture-Heavy!*&highlight=picture+heavy][b]My Prado Buildiup Since 2004[/b][/url][/color]
          [b]2004 120 GXL V6 4sp Auto D694 LTs and MTRs with Kevlar (best of both worlds )[/b]
          [url=http://www.fuelly.com/driver/lc120man/prado][img]http://www.fuelly.com/smallsig-metric/48063.png[/img][/url]
          • #35
            my winch is in so its time for the lockers now :lol: : :lol:
            -issue 52 Modified 4wds .
            • #36
              decided to upgrade exuast system so will be putting that in next week when i get back to Australia.....cant wait.... 8)
              • #37
                Hey Stan,
                Sounds good - let us know how you go. I'm thinking about winch options at the moment...
                • #38
                  I've decided to get one of these, saves me wiring in an in-cab switch. I can land one from the US for half the price ARB want. http://www.warn.com/truck/accessorie..._control.shtml
                  • #39
                    Originally I was going to put Warn 9.5XP winch, however the bullbar needs to be taken off in order to fit it...
                    I had a chat to a few Patrol guys who use Ironman winch almost every second weekend for the last 4 years without issues...
                    So at this stage I am learning heavilly towards Ironman winch with wireless remote + alloy fairlead and synthetic rope for about $1100.
                    • #40
                      Why does the bar have to come off? You fit it from underneath.
                      • #41
                        I don't know, but ARB told me the same thing as well - that the bar has to come off. :?
                        • #42
                          Its a lot less fiddly with the bar off but it most certainly can be fitted with the bar on the car.
                          I am leaning to the same thing though. The ironman winch has had some rave reviews from a lot a people and the no nonsense replacement warranty is just unreal.
                          • #43
                            IronMan 12000lbs winch gets fitted this Saturday.
                            Power: 12VDC
                            Single line rated pull: 12000lb (5443kg)
                            Motor: 6hp / 4.5kw, Series Wound
                            Control: Wireless Remote (Range 100ft) and Lead Remote (12ft Lead)
                            Gear train: 3 Stage Planetary
                            Gear reduction ratio: 265:1
                            Clutch: Sliding Ring Gear
                            Braking action: Automatic Cam lock in the Drum
                            Drum size: Drum size Diameter 2.52” (64mm) Length 8.8” (224mm)
                            Cable: 94ft of 3/8” diameter (28m of 9.5mm diameter)
                            Fairlead: 4-Way Roller Fairlead
                            Battery: Recommended: 650CCA minimum for winching
                            Weight: N.W. 90lbs (42kg), G.W. 98lbs (46kg)
                            Overall dimentions: Mounting Bolt Pattern (254-114.3mm)
                            :arrow: Wireless Remote with a range of 50 metres.
                            :arrow: Fitted with individual "ON/OFF" switch.
                            :arrow: Individually programmed to avoid accidental activation.
                            :arrow: Battery isolation switch to prevent any accidental use of the wireless remote
                            :arrow: Sealed waterproof bearings added to both ends for better stability & friction.
                            :arrow: Special O rings added for improved sealing.
                            :arrow: Improved cooling through the addition of an external heat sink.
                            :arrow: Individually balanced armature for improved operation at high speed.
                            :arrow: Zinc coated casing for added protection against moisture.
                            :arrow: Tungsten Tipped waterproof solenoids have been used to specifically provide long life performance and resist arcing.
                            :arrow: Improved sliding clutch with straight cut gears to eliminate “gearbox slip”.
                            :arrow: Improved clutch handle design to allow for easier use.
                            :arrow: Clutch handle has been “notched” to ensure handle lock.
                            :arrow: Premium quality high temperature lithium grease to reduce the effect of heat, water & oxidization.
                            :arrow: New Ironman stamped end cap for better sealing.
                            Each winch comes complete with an Ironman Winch Damper Safety Blanket. The Safety blanket will absorb the energy stored in the cable in the unlikely event of a cable failure.
                            :arrow: Made from heavy duty vinyl.
                            :arrow: Reflector strips for extra safety in low light
                            :arrow: Internal pocket to add extra weight or carry additional equipment
                            :arrow: New Automatic Cam Lock Brake System for greater safety.
                            :arrow: 4m plug-in hand controller included.
                            :arrow: MADE IN CHINA :twisted: :twisted: :twisted:
                            • #44
                              Well done LC, whats the damage for the 12,000 pounder?
                              2008 GXL M6 D4D, Silver
                              Build Up---> [url]http://www.pradopoint.com/viewtopic.php?t=2315[/url]
                              [b]{[/b]ATS Ridepro/Bilstein Lift[b]}[/b] [b]{[/b]Dual Batteries with RanOx Battery Booster[b]}[/b] [b]{[/b]600w Projecta 240v Inverter[b]}[/b] [b]{[/b]Dunlop AT3's / MT MTZ's on Speedy Grande Rims[b]}[/b] [b]{[/b]ARB Deluxe Winch Bar[b]}[/b] [b]{[/b]IPF900XS Spotties - Converted to 50w 4300k HID[b]}[/b] [b]{[/b]35w H4-3 4300k HID Hi-Lo Conversion[b]}[/b] [b]{[/b]ARB Underbonnet Compressor[b]}[/b] [b]{[/b]GME TX3440[b]}[/b] [b]{[/b]T-Max 10,000lb winch[b]}[/b] [b]{[/b]Safari Snorkel[b]}[/b] [b]{[/b]Milford Cargo Barrier[b]}[/b] [b]{[/b]Rhino HD Roofies & AT1410 Roof Tray[b]}[/b] [b]{[/b]60L Waeco[b]}[/b]
                              [img]http://www.gifs.net/Animation11/Transportation/Cars/4_wheel_drive.gif[/img]
                              • #45
                                very descriptive mate.....you should be a salesman :lol:
