Hey JGD any chance of a pic or two?
Mounting Light Bar to top bar of sovereign Bullbar
Time will tell, and it was something I did consider. I came to the conclusion that people run large UHF antennas from those brackets, even sand flags, both which have more movement. Having regard to the light bar, the weight is distributed between 2 brackets, so it should be sufficient. Short of welding 2 forward facing brackets to the bar then repainting (etc) there are not many other options.[size=2][b]Prado 120 - 2004 GXL V6[/size][/b]
[size=1]ARB deluxe bar, OME 2" lift, Safari snorkel, BFG A/T's, Ironman winch, LED bar, Redarc DC-DC dual battery, Rhino Rack Pioneer tray, Outback drawers and plenty of goodies inside. [/size]
Here's a couple of photos of my light bar installed, I welded a couple of tabs onto of the bar and tapped the thread into them, Had to cut the mounting brackets that came with the light to fit in the gap in the bar….. Does not stick out too far and sits there nice…. Feels solid as a rock so only time will tell i guess.
