Anyone had this problem and fixed it? i could not find it in the annoying rattles section. If i put pressure on the lever while driving on the road i can stop it, but it comes back when i take my hand off it. Any ideas before i take the console apart? 120 series 06 GX.
low range gear lever vibration
120 stick vibrates a lot as it goes straight into the box all is normal, just don't hang anything over it as it gets very noisy. ..
Hutch- Prado 150 with some TJM Kit.[b]Rob[/b]
Yep, totally normal they all do it, nothing to worry about.
I should have described it as a noise, rather than a vibration, but the 2 are linked. It annoys the hell out of me, it is like a buzzing sound, like a blowfly. It stops when i put pressure on the lever, i think it might be transferring the vibration to a plastic panel in the console. I did notice when i bought the car that a tab on the passenger side console plastic was sticking out from the silver trim near the gear levers. I thought an installer of the bluetooth phone hookup had previously left it out but it may have been done by the previous owner to stop the bloody noise. I pushed it back in to neaten it up but i may have restarted the noise that i didnt notice when i 1st got the car.
Just to follow up on the annoying buzzing noise from the low range lever, it has stopped after a wheel and tyre change. The old tyres were badly scalloped according to the mechanic so i would assume the irregular wear pattern was vibrating through the car. The new tyres are Bridgestone 694's on alloy wheels and the car drives well. Now i have squealing brakes as the rotors are heat affected and pitted. But at least i know how to get rid of that awful noise.
