gday, having trouble with my VSR100 led light not turning off after doing test with headlights on so the switch would turn off. Have had same setup in my old suzuki vitara with same Aux yellow top and worked fine, but now having charging issue in 120 series. Not sure if the VSR has finally givin up the ghost or something else. Im not new to dual battery setups but this has got me stuffed. Am using my solar panels that i have mounted to the roof for charging AUX battery. Thinking maybe the batteries arnt compatible but didnt seem to worry the vitara. My in-paralell switch works so there is power getting to it. Have done multipul voltage checks, the alternator is working maybe starter just not charging enough to activate VSR. Now i know that the projecta's arnt that expensive but it has worked for awhile now without any prob. these picks are of what i have and the config of sorts, hope the pics worked cause im new to this stuff. Any suggestions.
cheers
cheers
