UHF 2-way radios - Bearcat 880
  • UHF 2-way radios - Bearcat 880
    gday. anyone out there run the Bearcat 880 radio . looking into these at the moment and any feedback would be awsome. cheers
    I just did a quick search and could only find it listed as a 27 MHz CB.
    Are you sure it is an Australian UHF cb?
    155 SX with dual battery and Polyairs in the rear springs..
      It is a 27Mhz HF AM type radio not UHF. and does not even seem to have USB/LSB either.
      They still use 27Mhz in the USA. but one with side-band is a much better choice. (much greater range).
      The only reason to get a 27Mhz unit in Australia is if that is what your buddys are still using, in which case consider one of each.
      Most people in Australia now use 455Mhz FM, (now 80channels) I suggest you look at UHF FM radios like GME TX3345 or Uniden UH8060NB or you may want to consider a hand held unit...
      Steve
      2007 Prado 120 D4D 6 spd, 25/40cm lift ARB OME, snorkel, Brown Davis sump guard, Pirelli ATRs (Road), Cooper ST maxx (off Road), ARB lockers & compressor, Overkill rock sliders, dual D27F Optima Yelowtops, Ctek D250, 130A alternator, breathers, GME TX3440, Yaesu FT-857D, Buscomm Highlander 8 multitap or ATAS antenna, ARB Fridge. (VK2FSVN)
        ahhh... bugger... jsut bought one. no wonder they were so cheap then.. $240. next time i will ask the question and research a little more... so i shouldnt bother with this unit then? doin a trip to the N.T at xmas, only bought it to follow the chatter, cheers
          so would this unit be useless now here in oz... certainly having trouble getting any reception... i dont know enough about cb radio... does the arieal have to suit the radio? may have bought the wrong arieal too... bugger!
            Yep, send it back if you can.
              cant send back.... bugger... apparently 27mhz is what they use here in auz for marine radio.... might have to throw it in my boat if its true... cheers
                Marine radio in Australia uses the frequency range 27.68 to 27.98MHz.
                The Bearcat 880 operates in the frequency range 26.965 to 27.405MHz.
                  righteo amts,, cheers mate... looks like its a new radio goin in the bin.... bugger
                    Sell it to someone in the US??
                      If you bought it in Australia as a UHF CB radio it is clearly not fit for purpose.
                      Why can't you return it for a refund?
                        bought it off ebay. yes as a brand new unit. from an australian seller.... will follow it up sweetpea.. dont like my chances though
                          eBay buyer protection might be able to help. Good luck
                          Blake
