I was helping someone at Nagala rocks bypass on Fraser and they melted a bunch of teeth off my brand new Maxtrax. I was disappointed that they guy didn't listen when I said to go easy and not spin the wheels, but I was also surprised how easily you can melt lugs off.
I spent a good chunk of cash buying these and now they were not going to be as effective with a bunch of lugs worn off.
The damage.... Pretty much all 4 look like this.
While driving back to Brisbane came up with a plan to do some dentistry and make them better than before.
Took me a week or so to refine the design. Lugs are same height as the original but a bit chunkier. I decided on an 8mm thread to hold it in place and a low profile nut so that I could still stack the Maxtrax on top of each other on the Maxtrax mounting pins.
Maxtrax CNC machined Stainless steel tooth.
Installation involved drilling an 8mm hole from underneath the lug and then cutting off what was left of the lug. It was pretty easy to cut.
Tooth has been implanted. Bit of bling looks good. It very solid. Don't think it will melt in a hurry.
Underside view. Low profile so the Maxtrax still stack.
Really happy with the result. Looks quite good with the shiny metal on orange contrast. I only made 4, but looking at the carnage again, I'll probably need alot more.
