Maxtrax Dentistry - tooth replacement
    Hard plastic with a metal screw from behind (keep it clean mlc).
    Originally posted by Tin175 View Post
    Could also round off the stainless version so that its not so aggressive and sharp. More of a nipple or rounded stud shape.
    Yes, a nipple with studs and no plastic. Sounds more natural yet adventurous. Kinky but keeping it real so to speak.
      Ahh a truly worthy post. I can identify with that!
        I just used some short 8mm bolts with a washer either side of the plastic and double nuts on the teeth side, doesn't look anywhere near as pretty but works well, and if some nob spins it up heaps it just tears his tyres up not my trax
          not sure if they will work or not but they look like an amazing piece of engineering, they look a million bucks.
          well done
            just had a thought, some screw in tags off a pair of footy/soccer boots would be a good replacement cheap and readily available to
              I had considered the football studs. So long as you can get a suitable nut to screw to attach it. Also might stick out too far making it hard to stack them. I agree, that they are a very cheap.
                How about delrin? Would that be tough enough? Certainly easier to machine than SS (cheaper).
                Nova
                  They are awesome!.
                  The pink MAXTRAX on MUMSRIG have been worn down significantly over the years and need a bit of dentistry...
                    Thanks for sharing about Maxtrax Dentistry, and I hope you find a tooth replacement option that works well for you!
