Hi all,
I have just wired up the solar relay for my Redarc 1225 BCDC charger however I'm having issues with the solar input. It appears to be an issue from the solar panel end.
I have a 120w folding Projecta panel which has a PWM regulator on it. I thought it would be as easy as unscrewing that regulator and rejoining up the wires. Under no load I am getting 20 volts. When connected up to my car I am getting about 16.5 volts at the panel under load. My Redarc 1225 needs 17.5 volts from the panel to charge. Lex at Redarc advises that it looks like there is a problem with my solar panel (which is brand new) as it should be regulating to in the vicinity of 18 volts.
Have I bypassed the Projecta PWM regulator correctly (it isn't connected at all now) or do I need to unstitch the fabric on the panel to do something to the wiring inside?
Dane.
Dane.
