Rust on frame of 2.8 GXL prado
many thanks Bear 63... even the toyota dealer are not sure why it is there.. so will wait for their reply & will post here.Originally posted by Bear63 View PostIts not rust its the welding melthod used , its like a bronze weld the paint on the chassic wont stick to it , looks horrible but not detrimental , you see alot nowdays
Except when the tsunami came in and flooded the yard where they had all the Tojo chassis stock-piled.Originally posted by nirmal2016 View Postnever been near to sea.Dave
I've had this on the last couple of my new 4x4 chassis, as has been said I think it's fairly normal. I just cleaned it up as best I could and hit it with some chassis black.. all good.2016 Toyota Prado GXL auto. ARB deluxe bar, Rock Armor side steps, 9in Penetrator LED spotties (30,000LM), Uniden 8060 UHF, Bilstein/Dobinson 2in lift, 265/70/17 Mickey Thompson ATZ P3's, Safari snorkel, Dual battery system, ARB onboard compressor, Custom rear false floor, Kaon bash plates, Ext. diff/gearbox breathers, Provent 200, Wynnum tow bar, Roadsafe tow points, Phillips crystalvision bulbs, tint, Rhino rack platform.
I spot sprayed all 'rust' looking spots on the welds when new with flat black rust converter and it has survived several beach trips including Fraser several times and looks like new when cleaned. I also pissed off the factory bash plate and touch the ARB one up with matching cold gal every six months.
Sent from my iPad using Tapatalk[CENTER][B]-=2014 GXL D4D Auto Graphite, Firestone Airbags, ARB/Optima D34 Dual Battery, ARB UVP, TJM Airtech Snorkel[/B][B]=-[/B]
[/CENTER]
