Transfer case oil leak
  • Transfer case oil leak
    Greetings from NZ.
    I bought a new Prado D4D in 2014 and after 60,000 kms , I have a transfer case oil leak. The local Toyota dealer has replaced the seal saying there was very little lost oil so no probably no damage to internals. Can anybody throw some light on what could cause the seal to fail and should I be insisting on a full inspection of the case under warranty? I have done occasional sand driving and some fairly easy 4x4 stuff and only tow a lightish boat and camping gear.
    Got a 5 hour tow of a 2.3ton boat and my gear at Xmas though and concerned!
    Thanks for any advice.
    Originally posted by Matuhi View Post
    Greetings from NZ.
    Transfer case front output seal failure is common when driven on sand. It gets in under the wiper and wears the seal till it leaks.
      yes that is what happened to me 6 mounths ago ,Also i lost a lot of oil , i do have a slight winde now that i assume is the transfer csae but not sure ,and im not sure what to do about it .. ,,, i remember doing a fair bit of sand driving and i have to say that it seems logical , also i have 270 k on the clock so also a tired seal it was to say the least ,
        Thanks Adrian and Tony for your replies. Sounds like a good hose down in that area is needed after sand driving. Hopefully got it in time. Bet I will be hearing things from now on though!
        cheers.
