I'm currently investigating getting a fridge/freezer myself.
I have a cargo barrier, cargo shelf and drawer system with sliding top (for a fridge).
Unless I mount the fridge sideways, most 60Ltr and up fridges will not fit. My tie-down rails front and back take away a few centimeters each of usable length, the Cargo barrier takes some away also so I'm left with about 740mm Length max. A 40L Engel will fit but a 60L Engel will not. A 60Ltr SnoMaster will fit just.
Thanks for the reply. How much more room do you think you would get without the cargo barrier being there? And sitting on a slide on the floor not on drawers?
My cargo barrier hugs the shape of the middle seats so it only takes maybe 10mm width. There's a 100mm back without my drawer system.
You should get a 60Ltr unit in, but the 95ltr unit is nearly a meter long. Too long,
I'm a bit late but I'm I had the same question. I wanted a 60l fridge for my 120 to fit behing the cargo barrier. I discounted the engel as the controls are in an awkward spot, plus no drain plug. I measured the ARB 60l fridge and figured I would have 10mm clearance to the back door so that was a no. I bought a Waeco CFX65 yesterday, it has 130mm clearance to the back door and fits well. The ARB is a low, long design wheres the Waeco is shorter and taller. The ARB would probably have been easier to use, with less need to dig down to find things, but I'm sure I'll be happy.
