Fabricating steel heater pipes
  • Fabricating steel heater pipes
    Well the steel heater pipe on my 1996 VZJ95 has suffered bad electrolysis and is proving difficult to source new. Consequently I made one.
    The original is 17mm OD and the nearest I could get locally is 16mm galvanised tube from Bunnings, 1.2mm wall thickness. So first I made a swage to open the ends up to 17mm.
    Next, the original tube is a mandrel bend about 25mm radius. So I turned up a round die on the lathe and made a straight die for maximum support when bending.
    I filled the tube with lead to prevent collapse and bent it OK.
    I then made the tube water seal beading using internal crimp dies held in a vice while the tube was indexed around a bit on each crush.
    It came up pretty good in my opinion. I just need to weld on a bracket tomorrow.
    I plan on using a similar technique for oil hoses and even custom diesel fuel hose bends on my troopy when I install a pre-filter.
    Rob
