Lift Regulations
  • Lift Regulations
    Lift regulations, this is what has just been sent through to me. They need to actually drive a vehicle that has had its suspension fitted with after market gear and even a slight lift. I know for sure my prado doesnt nose dive under brakes like it use to and the ride there is no comparison to the factory stuff that was fitted to it. https://leaders.myelectorate.com.au/crm ... qid=168979 Regards Steve M
    Re: Lift Regulations
    Hi Steve
    What is it that they dont know stuff about?
    cheers
      Hi steve
      I received this today as well. Without starting a war, I think it is a good result. Unless I have misread it, what I have gleaned in sumary is:
      :arrow: up to and including 50mm - basic certification e.g. if ARB installed it, a simple statement on the receipt (bit like window tinting)
      :arrow: 51mm-150mm - engineer certificate and blue slip - pretty onerous, but probably not a bad idea. I have seen heaps of 4-6" lifted cruisers and patrols that have not been done properly and quite frankly, are an accident waiting to happen.
      :arrow: over 150mm - it's all over red rover - and so it should be!! Why anyone needs a lift over 6" on a street car is beyond me.
      I would even question anything over 4", but I won't :twisted:
      andy
      Black 2003, TD, GXL Prado
        Interesting & I think a reasonable compromise.....
        I see that if you go over 50mm you may need to pass a severe lane change test..... ISO 3888
        There is a video of such a test below...
        http://www.youtube.com/watch?v=0KBIBCK-veA&NR=1
        I wonder how my standard Prado 90 with 9 year old suspension would handle that as it is? In fact it probably would be better WITH aftermarket suspension in this test. :shock:
        Richard
        2011 GXL TD Auto Prado Silver
          Good to see you can mod a vehicle fitted with ESC to 50mm, previous draft said no mods
            Originally posted by Steve M
            Lift regulations, this is what has just been sent through to me. Sorry just reread it, I thought at first it was saying even a 50ml lift would require a engineers certificate. This is different to the one they proposed earlier this year.............link................ https://leaders.myelectorate.com.au/crm ... qid=168979 Regards Steve M
              Hi Tassie tiger, sorry just reread it again, I thought they were saying a 50ml lift would require an engineers certificate...But in saying that most 4wd's handle and drive better with aftermarket suspension even with a 50ml lift. I know a fair few people who have either patrols or cruisers and a fair few have 3in lift, even a tour company my wife and I have used on numerous occasions has a 3 inch lift in his patrol, anymore then that personally I dont think is required for touring, carrying loads or general everyday driving. Ill never need to worry about it anyway with the prado..Regards Steve
              Originally posted by tassie tiger
              Hi Steve
              cheers
                Yes D4D was a bit concerned about that myself as mine has it as well. I could get mine to cut in before and after the lift and doesnt seemed to have changed anything. Doesnt cut in any later or earlier then prior to the lift. Regards Steve
                  Hi there StormyKnight, I can definately say mine handles better, doesnt wallow over speed humps, doesnt nose dive under brakes, and can hold the rear end up with both tanks full where as before it would drop down considerbly, bounce over speed bumps. Regards Steve M
                    Yeah Andy must aggree with anything over a 3 in lift, I dont see the purpose in say a 4 or more as they definately seem to have extreme body roll and dont think Id like to be in one in an emergency situation, but then again I have never owned one with such a lift so maybe Im wrong in my assumption ??? I think if done by proffesionals then probably all right but then you get people who just wack in some 4inch or more springs, wack some shockies in and go for it. Regards Steve M
                    Originally posted by Prado BB
                    Hi steve
                    andy
                      I think they may have picked 50mm as the first lift point because most vehicles can handle this without any caster issues or CV issues surfacing.
                        You will still require an engineers cert for only a 50mm lift if it involves a body lift (blocks, spacers, etc.) of any kind instead of going down the more common route of suspension mods. (Any lift involving the body requires the same certification as a 50-150mm lift).
                        Found the Road Vehicle Descriptor sheet for the 120 (also noticed it was found for another suspension thread too). The official 'trim' measurements (those used to determine the amount of lift allowed - measured from centre of wheel to top of wheel arch at unladen mass) is 522mm and 558mm front and rear respectively. Thus, according to the new regs, the max lift without a cert will result in measurements of 572mm and 608mm front and rear. Anything lifted between 50mm and 150mm needs an engineers cert, but it also then requires a check by an Authorised Examiner at an Authorised Unregistered Vehicle Inspection Station (AUVIS) - i.e. a 'blue slip' inspection. The vehicle MAY then have conditions imposed on the registration that may restrict the use ON-road and road related areas. Surely if an engineer approves it there is no need for a second inspection?
                          [quote="Way2go"]
                          Where did you find the hight sheet?
                          Just wondering if it the same hight for a 150 Prado.
                          150 Prado D4D GXL Blue Storm, T13 TJM Bar, 265/70/17 Goodyear MTR Kevlar, Tigers11 1200 pound 2 speed Winch, Fox Shocks remote resevor, Air tec Snorkel, ARB Air Lockers Front and Back, Off Road Systems Draws with Drop Down Fridge Slide, Wetsuit seatcovers.
                            Try in the 2 supension threads round about june/july 2009- I recall posting the links there and seeing other links as well. In general, just dig around on the RTA site for vehicle specs. Neil
                              Link for the 150 sheets is here - http://rvcs-prodweb.dot.gov.au/pls/w...RUISER+150+SER
                              Depending on the model front measurements range from 513 to 552 and rears from 548 to 558.
