Summary of modifications and Post (#) references
Ok, been on here a while but never tackled this so here goes.
Bought the rig in October 2010. basically stock standard Silver Grande 2009 with 22k on the clock. Arranged for the genuine Yota tow bar, ARB deluxe bull bar with winch and fogs.
- ARB deluxe colour coded bull bar with LED park and indicators. #2
- Runva 11XP Premium Black winch with remote unit.
- 30m Dynamica rope #226
- IPF extreme 900 spotties, 2 x spot and 1 x spread beam #2, # with HID upgrades to 100AMP
- Fog lamps and indicators, #2, #200
- Mine spec sand flag and hold down clip #24
- Low profile windshields to all windows. #13
- AJ120 modified rock sliders #9
- 2" lift with King remote reservoir adjustable shocks and front springs
- Cooper STT 265/70/17 with Kaymar Spacer on the back for the spare. #2
- Icom 440 UHF, GME AE4705G UHF H/D Radome Antenna, GREY 6.6dBi #3
- Icom 450n UHF, GME AE4705G UHF H/D Radome Antenna, GREY 6.6dBi, plus GME AE4706G UHF H/D Radome Antenna, GREY 8.1 dBi
- Safari Snorkel #2
- Duel battery Fullriver 120AH housed in battery box with guages and outlets. #2
- UHF & rear power connected to second battery #2
- 3x aux power to second battery (one in glove box and 2 behind centre console ##42
- Rear Power board incl: 3 x cigarette outlets, 1x Engel outlet, 1x merit outlet, 1x 50Amp Anderson, all running from second battery with volt meter at rear. #278
- Dual voltmeter in cabin #116, #278
- Low water alarm with dash light #347
- 100 amp fuse box #13
- Billet Racing quad breather to front & rear diffs, tfr case and trans. #101
- Raised fuel breather #
- Front & Rear ARB air lockers #10, #63
- On board ARB compressor. #2
- Toyota Towbar, Anderson plug with Projecta isolator to trailer batteries #2
- Wet Seat front and rear seat covers #27
- Personal plates: PRADO9 (Was 120D4D) #11
- Cargo barrier, #37
- Fourby Fitout rear drawer, shelves and fridge slider system and 40l Engel and 78l ARB #37
- 2x fire extinguishers (mounted) #47
- P14 LedLenser torch (installed) #54
- 3 inch Manta Stainless Steel Exhaust System. Modified tail pipe to exit behind rear drivers side. #77/81/83/88
- LED interior lights, front, centre and rear
- EGT Monitor
- amts Custom Bash Plates #145/146/184
- On board compressor #2
- Rhino Rack with 1350mm cross bars #
- Dash override switch for starting from second battery #
- Custom Catch Can #518/521
- Turbo Timer #
- RhinoRack and longer Toyota Cross Bars. #
- Rear AJ120 custom Bar (changed from a MCC Twin Wheel Carrier #375/379/459/468/525), custom mud flaps.
- Total Traction Tyres Fairlead
- Bug Bra #23
- Bonnet Protectors #116
- Oil Drain Valve #117
- 3 x sets MaxTrax #240
- GoPro2 Mount Points #471
- Newpro Tech 14.4K LED Light Bar #623
- T3 DBA Rotors all round with Heavy duty Bendix pads.
- Upgraded beams to HID.
- New motor @ 79,000!
- 2nd UHF (80 channel Icom 450n) and large GME aerial + 1.2 m aerial #701
- Custom scrub bars (AJ120 made)
- Bonnet scoop (Cross Country 4x4)
- RedArc 25AMP in-vehicle battery charger/MPPT Regulator. (BCDC1225)
- Davies Craig Transmission Oil Cooler (additional to existing)
