Rig Build 120 D4D Grande - 'MLC'
  • Rig Build 120 D4D Grande - 'MLC'
    Summary of modifications and Post (#) references
    1. ARB deluxe colour coded bull bar with LED park and indicators. #2
    2. Runva 11XP Premium Black winch with remote unit.
    3. 30m Dynamica rope #226
    4. IPF extreme 900 spotties, 2 x spot and 1 x spread beam #2, # with HID upgrades to 100AMP
    5. Fog lamps and indicators, #2, #200
    6. Mine spec sand flag and hold down clip #24
    7. Low profile windshields to all windows. #13
    8. AJ120 modified rock sliders #9
    9. 2" lift with King remote reservoir adjustable shocks and front springs
    10. Cooper STT 265/70/17 with Kaymar Spacer on the back for the spare. #2
    11. Icom 440 UHF, GME AE4705G UHF H/D Radome Antenna, GREY 6.6dBi #3
    12. Icom 450n UHF, GME AE4705G UHF H/D Radome Antenna, GREY 6.6dBi, plus GME AE4706G UHF H/D Radome Antenna, GREY 8.1 dBi
    13. Safari Snorkel #2
    14. Duel battery Fullriver 120AH housed in battery box with guages and outlets. #2
    15. UHF & rear power connected to second battery #2
    16. 3x aux power to second battery (one in glove box and 2 behind centre console ##42
    17. Rear Power board incl: 3 x cigarette outlets, 1x Engel outlet, 1x merit outlet, 1x 50Amp Anderson, all running from second battery with volt meter at rear. #278
    18. Dual voltmeter in cabin #116, #278
    19. Low water alarm with dash light #347
    20. 100 amp fuse box #13
    21. Billet Racing quad breather to front & rear diffs, tfr case and trans. #101
    22. Raised fuel breather #
    23. Front & Rear ARB air lockers #10, #63
    24. On board ARB compressor. #2
    25. Toyota Towbar, Anderson plug with Projecta isolator to trailer batteries #2
    26. Wet Seat front and rear seat covers #27
    27. Personal plates: PRADO9 (Was 120D4D) #11
    28. Cargo barrier, #37
    29. Fourby Fitout rear drawer, shelves and fridge slider system and 40l Engel and 78l ARB #37
    30. 2x fire extinguishers (mounted) #47
    31. P14 LedLenser torch (installed) #54
    32. 3 inch Manta Stainless Steel Exhaust System. Modified tail pipe to exit behind rear drivers side. #77/81/83/88
    33. LED interior lights, front, centre and rear
    34. EGT Monitor
    35. amts Custom Bash Plates #145/146/184
    36. On board compressor #2
    37. Rhino Rack with 1350mm cross bars #
    38. Dash override switch for starting from second battery #
    39. Custom Catch Can #518/521
    40. Turbo Timer #
    41. RhinoRack and longer Toyota Cross Bars. #
    42. Rear AJ120 custom Bar (changed from a MCC Twin Wheel Carrier #375/379/459/468/525), custom mud flaps.
    43. Total Traction Tyres Fairlead
    44. Bug Bra #23
    45. Bonnet Protectors #116
    46. Oil Drain Valve #117
    47. 3 x sets MaxTrax #240
    48. GoPro2 Mount Points #471
    49. Newpro Tech 14.4K LED Light Bar #623
    50. T3 DBA Rotors all round with Heavy duty Bendix pads.
    51. Upgraded beams to HID.
    52. New motor @ 79,000!
    53. 2nd UHF (80 channel Icom 450n) and large GME aerial + 1.2 m aerial #701
    54. Custom scrub bars (AJ120 made)
    55. Bonnet scoop (Cross Country 4x4)
    56. RedArc 25AMP in-vehicle battery charger/MPPT Regulator. (BCDC1225)
    57. Davies Craig Transmission Oil Cooler (additional to existing)
    Ok, been on here a while but never tackled this so here goes.
    Bought the rig in October 2010. basically stock standard Silver Grande 2009 with 22k on the clock. Arranged for the genuine Yota tow bar, ARB deluxe bull bar with winch and fogs.
    MidLifeCrisis
    Out of control poster!
    Last edited by MidLifeCrisis; 03-05-2016, 10:13 AM. Reason: Updated mods done to 31/8/2012
    Re: My Rig Build
    Next step was IPF extreme 9000 spotties, Safari Snorkel, and Kaymar spacer for the rear door as well as Cooper ST 265/70 R17s.
    MidLifeCrisis
      Re: My Rig Build
      Electric Bug fitted the ICOM 440. It is hidden under the centre console (somewhere)
      MidLifeCrisis
        Re: My Rig Build
        Next was the 2" lift done by the guys at total Traction Tyres in Lonsdale SA. They used the Darren from Autocraft method. Bilstein shocks all round with easy rider springs in the front and some secret adjusting and welding on the rear air bags. Lost the comfort setting (which I only used once anyway), but still have the auto ride levelling and ability to lower or raise the rear for trailer and of road occassions.
        MidLifeCrisis
          Re: My Rig Build
          Looking good mate... Was wondering when you'd start your buildup page!!!
            Re: My Rig Build
            Getting there. Had some spare time last night while you were drinking wine and driving fast cars. Hope you didn't try to 4wd in the Audi or statesman!!!! :wink: How are you placed for tonight?
              Re: My Rig Build
              Looking good there, did you have any troubles with your size coopers before installing the 2" lift?
                Re: My Rig Build
                Yep, rubbed on full lock, otherwise ok. Once the lift was done all rubbing stopped.
                  Re: My Rig Build
                  Added some rock sliders from Autocraft. Again fitted by the boys at Total Traction Tyres in Lonsdale.
                  MidLifeCrisis
                    Re: My Rig Build
                    Had ARB install front and rear airlockers. (No pics)
                    Installed Billet Racing quad breathers to the front and rear diffs, tfr case and transmission. Also raised the fuel breather up inside near the fuel filler.
                    MidLifeCrisis
                      Re: My Rig Build
                      Got some personalised number plates. If anyone is interested "PRADO" is still available in SA!!!
                      MidLifeCrisis
                        Re: My Rig Build
                        Originally posted by MidLifeCrisis
                        Doesn't look like much of a lift when I crawl under your rig... :shock: :shock:
                        Anytime, you need some help mate - just need to bring suitable payment (beam & coke)...
                          Re: My Rig Build
                          OK, this lists everything else to bring the build up to date:
                          1. Quick release sand flag
                          2. 100amp fuse box to tidy up the mess under the bonnet
                          3. New Stebel 139db horn to replace the pathetic excuse for noise that Toyota put on as standard.
                          4. Non "Granpa" visors
                          Again, big thanks to Matt (Matt & Loz) for the assistance with installing items 2, 3 and 4.
                          MidLifeCrisis
                            Re: My Rig Build
                            Build up to 28 Feb 2011:
                            Body work:
                            1. ARB deluxe colour coded bull bar, warn 9000 winch, IPF extreme 9000 spotties, fog lamps and indicators, quick release ARB sand flag.
                            2. Low profile windshields to all windows.
                            3.Autocaft Rock sliders installed by Total Traction Tyres in Lonsdale SA
                            4. Autocraft 2" lift with Bilstein shocks and easy rider cols on the front (air bags modified on rear) installed by Total Traction Tyres in Lonsdale SA
                            5. Cooper ST 265/70/17 with Kaymar Spacer on the back for the spare.
                            6. Safari Snorkel
                            Electrical:
                            1. Icom 440 UHF, GME 4705 antenna
                            2. Duel battery system with Redarc isolator. UHF & rear power connected to second battery.
                            3. 100 amp fuse box
                            Under body
                            1. Billet acing quad breather to front & rear diffs, tfr case and trans.
                            2. Raised fuel breather.
                            2. Front & Rear ARB air lockers, on board compressor.
                            3. Towbar, Anderson plug.
                            Other:
                            ARB tyre repair kit
                            Exhaust air jack
                            Personal plates
                            Recovery Gear:
                            1. Snatch strap
                            2. Equaliser strap
                            3. Bushranger long handle/short handle 4 piece shovel
                            4. Tree trunk protector
                            5. Rated d shackles
                            6. bag
                            7. block
                            8. ARB deflater
                            9. ARB hose and gauge
                            10. separate compressor with Anderson plug connections for rear use to camper trailer.
                            11. Bush Ranger tracks (work like maxtracks)
                            I think that's it.
                              Re: 2009 D4D Grande - My "Mid-Life-Crisis"
                              Matt
                              Thanks for changing the heading..... I think....
                              My recollection is that is NOT what I suggested, but after looking at my credit card is probably apt. :shock:
