Beast2h's Prado
  • Beast2h's Prado
    I've been on here a while. Here is my prado.
    285/75R16 MTZ's
    ARB Bar
    Lightforce 240 Blitz's
    60ltr Engel
    Tigerz11 Winch and Roof Rack
    Fox Wing Awning
    Pioneer head unit
    Dual Batterys
    Safari Snorkle
    Wish this photo had been taken a little closer
    75 Series Cruiser No More
    Replaced with a G6E Turbo
    95 Series Prado [url]http://www.pradopoint.com/showthread.php?19936-Beast2h-s-Prado[/url]
    Re: Beast2h's Prado
    A while??? Ya reckon!
    2006 - anyone would think you invented PP...
    By the way, nice flex!
      finally got around to doing the well know dash fix
          it made all the difference and should be much better up the cape this year
            Nice! I think I should look into this mod, mine rattles almost as loud as the music
              Great looking 90 Beast2h, both my dashes rattled in my 90's the 01 grande been the worst, it was shocking thought the bloody thing was going to end up in my lap on rutted stuff even with tyres down to 22/24 use to have to push my hand against it to shut it up a bit, real bad design by toyota. They obviously didnt listen to any customers cause nothing was changed in the mounting design between series one and two...........Cheers steve
                Ok, here is a link to solve the dash noise problem in our 90/95 Prados:
                http://www.kdjoteros.com/Brico.Ruidos.php
                Is in Spanish but with the pics, I think it could be understood!!
                Prado RZJ90. OME 881 coils Nitrocharger Sport shocks front, 80 Series front coils & rear 80 series Tokico shocks rear, 255/85R16 Cooper Discoverer ST, Viper rocksliders, parking brake cable rear axle bracket, extended rear brake line, extended diff breathers, headers, engine perfomance mods, soon LR upper control arms, ARB rear locker in the future.
                  My First attempt at a Laptop mount come up alright so far!
                    getting ready for the cape again so I'm hoping the Prado changes a little in the next 7 weeks!
                        I got another optima battery for the Prado I have fitted it in the factory position as it is the same size as a n70 but taller so I had to make a new clamp bracket that would use the factory hold down points, and fit under the bonnet! I also moved my small optima to the other position.
                          thought it would be best if I had a go at stopping the rear tires rubbing. I've been meaning to do this for a long time! haven't tested it yet, I may still have to extend the bump stops a bit or do a small body lift, I'm not all that keen on the body lift as I am quite happy with the height as I can still get into most underground car parks.
                          Had to modify the standard flaps so they would fit back up neatly
                          I moved the steel bracket back about 25mm
                          I will take a few pics fitted soon
                              Nice to see another person tackling the wheel arch mods and documenting it
                              I don't recall seeing that steel bracket.. will have to take another look at mine. (lost another rmud flap )
