Originally posted by 1coolbanana
View Post
1Coolbanana's Grande Build Up
Meet you in the middle huh
Hang on, wait a minute, you already got two greenies!
Is there something youre not telling me!Marc, 2003 Grande V6, Just a Bit of Stuff Done.....
.....Work in progress.
Ok, so I couldnt wait!
Bugger of a job on your own, bloody heavy and without ramps but its all on and looks tops
Once again, thanks Andrew.
So diff drop is in and the plates and hopefully get another 25-30mm lift in the front in the next couple weeks!
The front didnt drop at all with the weight of the plates and wasnt really expecting it too.
If you do the maths, theoretically would have only dropped about 1-2mm.
Will have to find another excuse for more lift
Last edited by 1coolbanana; 14-12-2011, 05:40 PM.Marc, 2003 Grande V6, Just a Bit of Stuff Done.....
First up with some coil spacers that Samo (thanks heaps Samo) very generously donated to the causeOriginally posted by craigm View PostMarc, what are you doing to get the extra lift?
I like the comfort of the HD TD springs that I have now, and messing about with different shocks and springs can be a bit hit and miss as we both have discovered.
So, stick with what Ive got and just preload the springs a bit with spacers.
Essentially the same as if you had Billies and moved the circlip up.
Ive got 15mm spacers so that should get me 25-30mm extra height at the front.
From my current 775-780 to 800-810'ish which isnt that high really.
The rear is a whole different deal and will mean using 80 series shocks and longer airbags and that = big money so that can wait for a bit.
Its ok fo now and I can tweak them up a tad more if need be.
MarcMarc, 2003 Grande V6, Just a Bit of Stuff Done.....
Good job Trekky
White, I saw it clear as day Banana.[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
