Homers 07 GXL D4D
  • Homers 07 GXL D4D
    Bought my 2007 D4D GXL in January this year and I am going as fast as I can to get it ready for a trip to Fraser Island later this year.
    Anyway, the Prado was completely stock when we got it apart from having the standard Toyota Sovereign bar fitted.
    Since then I have added/done the following:
    Fitted an Outback overhead console
    Installed a Dual battery system with Redarc Isolator
    Fitted some 265/70/17 Mickey Thompson ATZ 4 Ribs
    Done a 2” Lift using Lovells Springs and Bilstein Shocks
    Changed the standard sound system for a Pioneer DVD head unit with reversing camera.
    Fitted ARB CKMA12 Compressor under the bonnet
    ARB Deluxe Alloy roof rack
    OzTrail side awning
    ARB Color coded deluxe winch bar
    Wish list:
    Front and rear diff locks
    Warn 9500xp or Avenger winch & Plasma rope
    Cargo Barrier and draw system (still researching them)
    Wont even get started on the camper trailer ☺
    When we got it
    After MT’s fitted
    After the lift - look at the step line
    Overhead Console
    More to come...
    Paul
    Homer
    2007 3.0L D4D GXL, ARB Deluxe Winch Bar, dual batteries, Bilstein/Lovells 2" Lift, Mickey Thompson ATZ 4 Ribs, ScanGauge II, UHF CB & HF/VHF/UHF Amateur radios
    [img]http://www.fuelly.com/smallsig-metric/57576.png[/img]
    [URL="http://www.pradopoint.com/showthread.php?21244-Homers-07-GXL-D4D"]My Rig Buildup[/URL]
    Compressor
      Nice setup. Cheers.
      [color=#BF4000]2003 V6, Auto, GXL, Factory Bullbar, Rhino Roofbars, Bosch and Hella spotties, Cooper AT3, Bilstein shocks, Ironman awning, GME UHF, MaxTrax.[/color]
      [url]www.kymarphotography.com.au[/url]
        Fitted the ARB Deluxe Alloy Rack today...ARB replaced the Secondhand rail kit
          Looks good Paul, keep the photos coming!
          Geez I hope you didnt turn on the compressor with the shipping plugs still inserted into the air cleaner input...
          Micheal
          Micheal.
            Hehehe nah...I took them out first
              finally got around to fitting the awning this morning.
              Homer
                Fitted the new ARB Deluxe Winch Bar yesterday.
                What a mammoth job that turned out to be..I learnt a few valuable tricks too.
                See the pics below with my comments that might help others attempting to do this upgrade themselves.
                Getting ready to remove the old bar
                There is a bolt inside this tube(the one at the bottom) that needs to be removed, it holds the bar back against the chasis.
                The blocks in the chasis will need to be removed also to allow you to slide the metal guides with the captive nuts arb supply up the rails for the rear bolt holes.
                You will need to remove the bolts that hold the radiator in and gently push it back toward the engine to get these block out...that was a PITA.
                You will also notice that the top bolt had fallen out and was inside the plastic cover.
                Old bar off
                Homer
                  New brackets installed (driver side)
                  New bar in position....now here is a very valuable tip...put the parker/indicator and fog lights in the surround and mount it before you put the bar on...it is near on impossible to do afterwards and took me 2hrs to get the clips in that hold the surrounds in the bar.
                  We made some spacers out of 25mm pine to sit on the side wings of the bar to give us the required clearance and lifted the bar up to the right height and then bolted it up
                  Bar bolted on...lights in and bash plates underneath bolted up.
                  Completed..driving lights back on.
                  Hops that info is useful
                    Nice job Homer, well done
                    Just one thing, the side plates go inside the bar
                      Gee 1CB has been eating his carrots (good spot)
                      Lookin the goods Homer now you will have to update your signature unless your putting the soverign bar on as a rear bar.
                      Regards Adam
                        Looks a million bucks Homer - great improvement! And well done on fitting it yourself - do you get to spend the coin that you saved by fitting it yourself on something else?
                          Nice work you will have a ball at Fraser Island.
                            Doh...well that will give me something to do over the weekend.
                            Thanks for pointing that out 1coolbanana...i blame my father in law for that...bloody distraction he is
                            Updated my sig too ondaboat ..I do indeed get to spend the money on something else, should go close to buying a snorkel
                            Homer
                              Nice work Homer.
                              I found that some duct tape over the nut to hold it in place is a big help when you are putting the side plates back on the inside of the bar. Its a niggly job that you cant get your hands to otherwise!
                              Well done on the install mate.
                              Micheal.
