Yota's 150
    nice work yota, i need a high paying job like yours. cheers samo
      Wow, yota issome shopping list!!! Can't wait to see the pics.
      [b]Rob[/b]
        Will be one impressive machine Glenn
        Mike
        2005 GXL V6 Auto
        8 years of modifications
          finished up the dual battery today
          used a redarc solinoid and O gauge cable, metered 14v at the solinoid so not worrying about the booster diode at this stage. Havn't wired in the over ride switch yet though. Ran the cable around the back of the engine bay in some hign temp harnes flex conduit, and mounted the solinoid behind the air filter with a 6 way fuse block off the Aux batt.
          Glenn
          2012 GX TD 150 with long mudflaps - [url]http://www.pradopoint.com/showthread.php?23370-Yota-s-150[/url]
          1996 GXL TD 95 with no mudflaps (sold) - [url]http://www.pradopoint.com/showthread.php?12402-My-Truck-quot-Build-Up-quot[/url]
            Also picked up and fitted the new shoes, speedy only had 4 black chariots in stock and no date for restock, so changed to the flames. Much better looking than I thought they would be, actualy glad they didnt have the chariots.
            Yota
            Glenn
              Wow that looks awesum Glenn. This truck is gonna be a real weapon !!
              [CENTER][B][U]Matt
              [/CENTER]
              [SIZE=2]
              [/SIZE][CENTER][SIZE=2]
              [/SIZE][/CENTER]
                What size tyre did you end up getting? From memory they are a 17x7.5" rim?
                  the wheels are 17x8 the tyres are 265 70's
                  Glenn
                    Nice clean battery install and the wheels look trick as well...
                    [SIZE=2][FONT=arial narrow]2011 Crystal Pearl V6 Kakadu / 3M Tint / Prodigy Brake Controller / GME TX3440 UHF / ABR Battery Tray / Piranha DBE180S+ Isolator / Optima D34 Aux Battery / TJM Airtec Snorkel / ARB Colour Coded Deluxe Winch Bar / ARB Underbody Protection / Outback Ideas Recovery Points / Britax XRay 200 HID Spotties[/FONT][/SIZE]
                      Getting exited now, the truck goes into ARB on Thursday for the fit out. Then a very busy weekend to wire everything else up before we head off for a week. Just waiting for the blackwidow drawers to arrive and stage 1 will be complete.
                      Glenn
                        Hey Glen, when u removed the rear wheel cover did u put the 4 screws back in to seal up the holes?? R u able to give me any detail around the removal.
                        [b]Rob[/b]
                          yer, I just put the screws back in. the Kaymar goes on next week so the bracket will be coming off too, we'll see if there is anything in the kit that fills the holes or if they just put the screws back in aswell. The cover comes off real easy and looks much better IMO
                          Glenn
                          • #28
                            The whole rig is looking good buddy, with the ARB gear fitted it will re rockin.
                            [b]Rob[/b]
                            • #29
                              Picked her up this morning after her 2 day stay at ARB Newcastle, pretty happy at the moment. Bolted on the ariels and lights to see the final picture, now just have to spend tommorow try to wire them all up.
                              Overall I'm pretty happy with ARB Newcastle, but there were a few Friday arvo mistackes. Nothing major but considering the money I had just handed over I had expected a bit more.
                              Drivers side from wheel well, plactic not reatached fully, I had to push in a clip properly and bolt and cable tie it in better to stop the wheel rubbing on full lock.
                              At the rear bar the left mudflap was bolted to the kaymar braket, but the right side had been missed, like I said nothing major, But....
                              Yota
                              Glenn
                              • #30
                                Rear Bar
                                I guess this raised my satisfaction with ARB bit. They had to modify the wheel carrieres to accept the speedy rims, they replaced the wheels studs with longer ones, welded and painted, come up bretty good, if they hadent told me I wouldnt of picked it.
                                Yota
                                Glenn
