Originally posted by Hutch
View Post
Matt's 150 GXL
Sounds like a plan.. Will do[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][CENTER][SIZE=2]
[/SIZE][/CENTER]
hey matt.you going to the maitland 4wd,camping,fishing show in the end of may.i go every year want to check out the 150.m[SIZE=5][SIZE=1][SIZE=2][FONT=arial]120 gx 6sp man,tjm gold edition 2",maxxis bighorn,toyota ally bar with toyota super winch,light force xgt hid 50watt,duel batts,safari snorkel,diesel care secondry finer filter,redarc low coolant alarm,turbo timer,gme uhf,hema hn5i nav,tjm basket,red centre roll out awning,diy rear table...[/FONT][/SIZE][/SIZE][/SIZE]
Sounds like a good day out for all the hunter valley pradopointers.. I will be there !Originally posted by pradi2 View Posthey matt.you going to the maitland 4wd,camping,fishing show in the end of may.i go every year want to check out the 150.m[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][/CENTER]
When your here in Brisvegas Matt we should have a Pradopoint lunch, the Norman has great steaks and not far from Camira.
See ya on the tracks, Richo.
Sent from Richos iPhone using Tapatalk[B]Former [/B]Party Leader, [B]Now[/B] SDO SEQLD GTG 2015 PFA (Pradopoint Fairy Advisor)
Will talk to SWMBO and sort Out a date.[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][/CENTER]
exellant!!!Originally posted by Matt - mr4x4 View PostSounds like a good day out for all the hunter valley pradopointers.. I will be there ![SIZE=5][SIZE=1][SIZE=2][FONT=arial]120 gx 6sp man,tjm gold edition 2",maxxis bighorn,toyota ally bar with toyota super winch,light force xgt hid 50watt,duel batts,safari snorkel,diesel care secondry finer filter,redarc low coolant alarm,turbo timer,gme uhf,hema hn5i nav,tjm basket,red centre roll out awning,diy rear table...[/FONT][/SIZE][/SIZE][/SIZE]
First tank gone. 1000km for just under 100 litres of diesel and about $150. The old V6 used about 180 litres for the same distance !. Looks like I am saving about $70 each time i refill the new truck, compared to the old girl. I guess this will change once the roofrack, awning and the lift kit go in; but I really don't care as the economy is amazing me so far
Electric brake controller goes in next Saturday and lift kit early the following week hopefully...[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][/CENTER]
Hey Matt...welcome to the Lifestyle club...great bit of kit. Saw that up on the myswag page and thought it was a good buy. Looks like nothing left to do to it.Originally posted by Matt - mr4x4 View PostOh yeah, nearly forgot. Found a great deal on a Lifestyle 360i camper trailer over at myswag.com. Have placed a deposit on the camper and going to see it up in Queensland in a few weeks. If it's all good, I will be buying it and bringing it home.[SIZE=2][FONT=arial narrow]2011 Crystal Pearl V6 Kakadu / 3M Tint / Prodigy Brake Controller / GME TX3440 UHF / ABR Battery Tray / Piranha DBE180S+ Isolator / Optima D34 Aux Battery / TJM Airtec Snorkel / ARB Colour Coded Deluxe Winch Bar / ARB Underbody Protection / Outback Ideas Recovery Points / Britax XRay 200 HID Spotties[/FONT][/SIZE]
Cheers Michael. Hope it's a cracker. Will find out in a few weeks when I get up to inspect it and buy it I hope
[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][/CENTER]
Had a nice quite morning without any kids at home, so I decided to install my second battery tray. This is the second time I have installed a auxiliary tray in a Prado and since the first install was a success; just copied the install I did in the old 120 series GXL. From the photo's you will see that I glue insertion rubber under the tray and the side that mounts to the inner guard wall. This is to act as a vibration absorber and since this new truck is diesel, I deemed it more necessary that ever before to follow this practice.
Side Hole drilled thru inner guard
View from inside with inner mud guard removed
Hole repainted silver and some nice anti-rust spray slashed around
[/CENTER]
[SIZE=2]
[/SIZE][/CENTER]
More Pix :
Insertion rubber glued onto the underside of the tray
View from the top
Holes re-drilled thru the rubber for the mount bolts
[/CENTER]
[SIZE=2]
[/SIZE][/CENTER]
More Pix :
Another top view to show how easy this is to do
All finished, ready for a battery to go in
Pretty easy task, just need to be carefull you don't break the inner guard clips (I did and yes, had spares in my toolbox.. same as the 120 series guard clips/plugs). Take your time and it is a very easy and rewarding DIY job to do in the shed at home..
Hope this helps someone else.Last edited by matt150; 25-03-2012, 12:34 PM.[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][/CENTER]
Hi Matt
Enjoying the build up so far.
The battery tray looks nice and solid, is there some way that the bolt heads are covered?
I am guessing that more insertion rubber installs to recess them below.
Just spotted the tray on EB. so answered my own Q.
What battery are you planning on using?
Cheers TroyLast edited by foxclan; 25-03-2012, 05:22 PM.SOUTH AUSTRALIA GATEWAY TO THE OUTBACK!
Troy
Yeah there is a think insertion rubber insert (about 10mm) that goes in under the battery, to stop the rubbing against the mounting bolt heads. Going for maybe a full river deep cycle, will have to see what the money fairy says..... Build is progressing pretty quickly so far, electric brake controller and hopefully Anderson plug next Saturday, followed by new lifted suspension early before easter !!
Then we pick up the Lifestyle camper...... and that's another build up story all on it's own, that will be on myswag.com[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][/CENTER]
