Fido666's 150 Kakadu
Hi, yes I did post in that thread. Found more, but have not bothered noting it, as I'm wrong, about what I know to be a fact, happy to agree to disagree.Originally posted by mjrandom View Post#### what errors and have you told anyone or posted in that thread to correct the errors?
Sorry fido thought this needed to be asked.
Nice.Originally posted by craigm View Post
Um I'm confused now. If there are errors then they should be corrected, shouldn't they?Originally posted by Anth120playdo View PostHi, yes I did post in that thread. Found more, but have not bothered noting it, as I'm wrong, about what I know to be a fact, happy to agree to disagree.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Originally posted by fido666 View PostAnother mod crossed off the list today thanks to #############, a set of Dobinsons KDSS specific springs fitted to the front. The part number for the springs used was C59-726, this model is for KDSS equipped 150s with 50-100KG or so of accessories up front (i.e. bullbar and winch).
http://www.dobinsonsprings.com/docs/...df/TOY-100.pdf
I haven't changed anything else at this stage because I wanted to retain the Toyota TEMS shocks. I've still managed to gain a 65mm lift however this is expected to settle back down over the next month or so.
Heights for the front before were 760mm (L) and 745mm (R), after they are 825mm (L) and 810mm (R).
Sorry #### can't recall what the rears came up to since the airbags self-levelling sensors took care of that.
Anthony had some fun with the KDSS specific bits of the suspension but I'll let him chime in with any technical details (assuming they aren't trade secrets LOL).
I'll get some progress pics up as soon as I can work out how to get them off my phone, were sent to me in an MMS message.
Hi Fiddo666,
I followed your thread from your post on http://www.pradopoint.com/showthread...l-Kakadu/page4. Thank you for the link.
May I please ask when you say the self-levelling sensors took care of the rears... Do you mean that after the new front springs the rear will sit higher automatically to make the car level? I thought that the sensors needed to be adjusted to do this. Please explain as I am considering copying what you have done. It is such a worry as to obtaining the lean, that is holding me off doing anything. I also want to keep the current TEMS features.2013 Kakadu, pearl white, Cooper ST MAXX 275 65 18 123Q tyres, Safari Snorkel, ARB UVP, diff breathers, UHF GME TX3345, Red Arc 2nd battery, BMW luggage hdp, tint, ARB bull bar, synthetic winch, OME 2" lift, LED Intensity spot lights, ARB side steps, Kaymar rear bumper with 2 JC, spare and LED pole ligh, ARB compressor, ARB front air locker, Toyota rear diff lock.
Just went and did a quick measure for you on the driver's side with the rear set to "N", front is sitting ~810mm and rear is ~785mm so she's sitting a bit higher in the nose at the moment. My understanding is that we need to let the new springs settle before making any adjustments to the sensors to bring up the rear.Originally posted by Bawky View PostMay I please ask when you say the self-levelling sensors took care of the rears... Do you mean that after the new front springs the rear will sit higher automatically to make the car level? I thought that the sensors needed to be adjusted to do this.
Anthony might be able to explain the technical aspects if you send him a PM. Also a few of the build threads have info in them from people who have done this mod already.
Thank you for your extremely fast response. I have now sent him an PM. Thank you.2013 Kakadu, pearl white, Cooper ST MAXX 275 65 18 123Q tyres, Safari Snorkel, ARB UVP, diff breathers, UHF GME TX3345, Red Arc 2nd battery, BMW luggage hdp, tint, ARB bull bar, synthetic winch, OME 2" lift, LED Intensity spot lights, ARB side steps, Kaymar rear bumper with 2 JC, spare and LED pole ligh, ARB compressor, ARB front air locker, Toyota rear diff lock.
Fido just confirming you are measuring off the rim/tyre at the bottom so the front is about 795 in 17" speak. So pretty much perfect. You could tweak the rear to get to 840/845 and it would be fine. From what I have read on here it is an easy job to trick the sensors at the back anyway.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
I measured from the base of the rim to the top of the wheel arch panel through the center of the hub. The front wheel was on a slight angle but that shouldn't have thrown things out too much. I have 18" rims but I'm sure you know that, just mentioning it for the benefit of others reading.Originally posted by mjrandom View PostFido just confirming you are measuring off the rim/tyre at the bottom so the front is about 795 in 17" speak.
Had the car on the hoist at Anthony's today to tweak the rear airbag sensors. I was surprised there wasn't much re-decoration of the bash plates following our Wombat Forest adventure. Got a better pic of the TG150 while it was there :-
A bit dirtier then when it was installed but still perfectly intact too.
Photos of the air bag sensor tweaks to come, just off to dinner (we eat late around here).
The end result :-
Sorry for the cr@p photos, was battling mid-morning sunshine with the p & s. Anthony may have a better one.
I don't have the measurements to hand (forgot to write them down myself), perhaps Anthony can post them. I can say the front is sitting fairly level now and the lean in the back is no longer quite as pronounced, the difference being more like 20mm than the pre-tweak 35 mm. The Kaka when viewed from the side is sitting nice and level and not so nose-up as it was before following the new front spring install.
