Michelles 2012 150 Prado GXL D4D
  • Michelles 2012 150 Prado GXL D4D
    Hi guys, ive been quietly sitting back and keeping any eye on this forum for a while now with the expectation that it would be very useful when the time comes and i begin working on my wifes Prado.
    My wife and i have just had our first child, a little baby girl and thus my old Landcruiser Ute will be stepping down from the primary use vehicle on camping trips etc. but before it can be retired to boys trips only we need to get Michelles car up to scratch.
    We purchased the Prado new late last year but up until now it has remained completely stock.
    This was Michelles first trip out with the Prado along with our little baby girl. Bubs was 3 weeks old. Labor day long weekend.
    Notice, i had my old Landcruiser along for the trip also, as the Prado isnt setup to go out solo just yet.
    The first item on the list for us is setting up a dual battery system and running some power down to the back for a few sockets for the fridge etc.
    After researching here on Prado point i decided i would try and fit a 12" (std. N70Z) 4x4 battery in the Auxiliary battery location of the engine bay. However upon receiving the battery tray i discovered a number of issues with the tray and added together with the amount of bending required of the hard A/C lines i decided to return the faulty tray for a refund and purchased the ARB tray and a new, smaller battery. The AC Delco DCM24SMF.
    Ive also purchased the Redarc SBI12 Isolator to install on the ARB tray and also thanks to the information on this forum ive purchased the Voltage Booster replacement fuse from LeighW. As a matter of fact i just installed the replacement fuse today and its performed exactly as designed. Prior to fitting i measured 14.01V at the battery terminals with the engine started and running for a few minutes. Fuse replaced and the voltage now measures 14.50V. I was rather shocked by the state of my wifes factory (less then 12months old) cranking battery as i found its rested voltage (rested overnight) to be 12.10V this morning before i ran the engine...
    I will continue to monitor this now that im aware something could be up, but i think this is just further evidence that these modern 'smart' alternators are not looking after the vehicles battery(s) at all, and with the installation of LeighW's voltage booster hopefully the battery(s) will be maintained a little better.
    Thanks again for the information shared here, its been a big help to me so far and i hope that i can share my own experiences here and help out other members as well.
    Travis.
    His: 1978 FJ45
    Hers; 2012 Prado 150 GXL D4D Auto.
    [URL="http://www.pradopoint.com/showthread.php?28593-Michelles-2012-150-Prado-GXL-D4D"]http://www.pradopoint.com/showthread.php?28593-Michelles-2012-150-Prado-GXL-D4D[/URL]
    If i may share some of my passed trip reports with you guys please have a look at them if you havent seen them before.
    I very much enjoy putting them together however generally only do so for the bigger once a year outback adventures
    My wife and I spend a lot of time in the Victorian High Country and while we tend to get out by ourselves, now that we have the little one i wouldnt mind getting out with others in a similar position.
    2009 - Innaminka
    http://forums.overlander.com.au/view...p?f=19&t=73376
    2010 - Kimberley. No trip report but pics are here along with lots of others.
    http://forum.ih8mud.com/40-55-series...an-photos.html
    2011 - Simpson
    http://forums.overlander.com.au/view...p?f=19&t=73335
    2012 - Cape York
    http://forums.overlander.com.au/view...p?f=19&t=76610
    Travis.
    Alpinebully
    His: 1978 FJ45
      Welcome and good to see PP has given you some good info already. I look forward to seeing how your 150 comes out. Whereabouts is that photo taken? Looks a great spot.
        Welcome. I was just reading your past trips. Very impressive.
        07 White GXL D-4D & 6 Spd Manual. Sovereign Bar with 3 LF 240's. RedArc dual battery system. Icom Pro 440N UHF, Hilux washer upgrade, Ironman 2in lift and 4 new injectors
        Rig Build Up [URL="http://www.pradopoint.com/showthread.php?27854-Fronty-s-07-GXL"]http://www.pradopoint.com/showthread.php?27854-Fronty-s-07-GXL[/URL]
          Thanks for the kind words guys.
          mjrandom, Labor day long weekend this year we were camped out of Woods Point.
          Aprils second camping trip out was about 500m down stream of that last photo, at Easter.
          Fonty, glad you enjoyed checking out some of our previous trip reports. I'll be sure to put up any future Prado based reports here
          Travis.
          His: 1978 FJ45
            So, tonight i set about wiring up Michelles dual battery system. As per my original post, in the end i went with the ARB tray, Redarc SBI12 Isolator and the AC Delco DCM24SMF battery.
            The tray installation was very basic, the A/C hard line bracket needs to be loosened where it bolts to the body and 'slid' towards the front of the vehicle about 8-10mm. (The mount is designed such that this is possible with zero modifications required, just loosen the one nut, push the mount forward (towards the front of the vehicle) as far as it goes then re-tighten the nut).
            When positioning the battery tray you need to pay attention to the small rubber hoses (windscreen washer bottle lines? and the bonnet release cable) and make sure they are clear and wont rub or bind between the tray and the body. There is enough slack in these objects to push them clear and cable tie them if required in the location you are happy with.
            All in all, it is quite a tight fit, but it all fits in neatly with approximately 3-5mm clearance around the battery (from the guard, A/C line and the isolator when it is bolted up on the tray beside the battery).
            I had some off cuts of cable laying around so i used what i had. It was 2GA wire - 26mm^2. Terminals were Utilux 25mm^2 8mm lugs from Middys. (About $1.50ea - much cheaper then most Auto retailers sell them for, even cheaper at trade prices). All terminals were crimped with a hydraulic crimper, ends covered in heat shrink then put into split conduit.
            Last but not least, the Aux battery ground cable location... I searched and searched here but couldnt locate any information on where everyone was attaching the new ground cable so i chose an existing location with a hole and captive nut behind it on the guard. Using a dremel tool i carefully took the paint off and back to bare metal in the area where the lug would be bolted to.
            Despite what a lot of people suggest IMO i do not agree with running a heavy gauge ground cable back to the Main battery. 99% of the time it is fine but doing so can introduce / create ground loop interference issues thus as a rule i generally avoid it.
            Travis.
            His: 1978 FJ45
              Hi guys, well what a passed 24hours!
              I didnt think Michelle would be getting a bull bar any time soon (as in not in 2013), but what else is a bloke to do at 2am when feeding the bub but locate and buy a mint condition ARB Sahara bull bar for his wife.
              So, right now in the back of my old Landcruiser sits all of the bits and bobs that make up the ARB Sahara Bull Bar kit. Holy cow there are a lot of components!
              Next up, fitting bull bar + the latest 'Roadsafe' front recovery points. TBC.
              Travis.
              His: 1978 FJ45
                Nice, my Kakadu had one of those but somewhere between the previous owner and me it got swapped for a TJM T13. Nothing wrong with the TJM per se but they also took the winch that was on the ARB bar and I quite liked the look of the Sahara without the headlight hoops.
                What do you mean by "latest"? I'm still waiting on Roadsafe to replace mine with the new slightly modified design. My Kakadu has been the guinea pig as some TJM bars were giving issues with fitting them, ARB bars were fine AFAIK.
                  Hi Fido,
                  Sorry if there was any confusion re: the roadsafe front recovery points, nothing confirmed but by latest what i mean is to me they appear to be the latest version that ive read about on the forums here and on the roadsafe website. They have the elongated hole for the shackle to pass through, ground back section (i think, i wouldnt know for sure until i try to install them?) and come with 6 sets of bolts and the nuts with the mounting plate / wire thingumabobs IIRC. Purchased this week from e4WD in Cranbourne Vic. Bloke at the shop mentioned the elongated hole for the shackle being the latest change, i read about the back shape change here on PP and coming with 6 sets of the mounting hardware was mentioned on the Roadsafe website (earlier kits were sold with 4?) So i just assumed what i have is the current release from Roadsafe, and im hoping i dont have any issues fitting them
                  Travis.
                  His: 1978 FJ45
                    Do they look like the ones in post # 191 in this thread?
                    http://www.pradopoint.com/showthread...-Points/page20
                    The elongated hole was in my original set too, it's the shape at the top mounting points that has changed.
                      Hi Fido666, sorry for the delay its been quite a week this week. I dont think the recovery points we have match your ones shown on post 191 in your link. They look like the ones in post #100 in the same linked thread.
                      The ARB Sahara bull bar and RoadSafe front recovery points have been fitted. Michelle is very happy. Before any photos are made public i need to paint the majority of the front recovery points black, as according to the wife they look bloody horrible from the side and she isnt wrong! I will leave the bottom 'exposed' section yellow but will paint the main body of the recovery points black to match in with the chassis and ARB bull bar brackets.
                      Hopefully sometime tomorrow.
                      Travis.
                      His: 1978 FJ45
                        OK then, you have the original design. There's nothing wrong with it on an ARB bar, some TJM bars have issues.
                        Not sure how the Sahara bar is finished underneath but on my TJM bar the wing plates hide most of them from side view. I quite like the yellow, stands out from all the soccer mum crowd in my neck of the woods.
                          I painted the front recovery points for Michelle. They really only looked horrible when viewed on the exact angle which allowed 90% of them to be seen (when standing side on and looking through the gap between the tire and bar work etc). I painted them such that they were yellow from the point which they extend below the extent of the bar work.
                          Next up i need to wire up the spotlights, and then run some wiring to the rear of the vehicle and fit some sockets for fridge / compressor / lighting as desired.
                          I have purchased the wiring i shall use, twin core twin sheath 8GA. While ive tried searching ive found little solid information regarding exactly how to run this wire through the cabin.
                          If anyone has a link to a thread showing where it was routed and what, and how the panels were removed that need to be removed to run the wire this would be greatly appreciated.
                          Travis.
                          His: 1978 FJ45
                            Over the passed few days ive gone about running some wire down to the boot for a couple of accessory power outlets.
                            I ordered some twin core, twin sheathed 8GA wire on Ebay. I purchased the 6.9m bundle which turned out to be just about perfect, with perhaps 0.5m left unused.
                            I decided to run the wire down the passenger side of the vehicle as in the boot, the passenger side seemed the better of the two for access while running the cable and for locations to install the sockets.
                            I started by pulling up the passenger side rear door skid plates. Before you can remove the plate you have to remove the step plate for the back seat access - 2x10mm bolts. Then i simply pried the skid plate up starting from the back and working my way forward taking care to do it evenly and with as much support from underneath as possible so none of the plastic tabs were broken.
                            I then un-clipped the panel to the jack compartment and attempted to push the rear cup holder out. I was unsuccessful at that, and in the end i was able to pop it out by simply squeezing one side of it and pulling upwards. It was very hard to get it out the first time.
                            With the cup holder out i set about running some yellow tongue, from the rear door back and up into the boot area. It took quite a little while getting it right and in the end i found the tongue made its way up in front of the grab handle there. From there i had to encourage it forward via. the cup holder cavity.
                            The cable was tapped to the yellow tongue and pulled through to the rear passenger door cable track.
                            The clips containing the factory wiring loom are opened and my twin core twin sheathed 8GA cable was then run along side the factory wiring loom. The wire needs to be run on the outside, side of the factory loom.
                            Once the wire had been run all the way through the car i cable tied the wire around the factory loom at each center between the factory clips and in a few other locations to stop and potential rubbing etc.
                            His: 1978 FJ45
                              Same thing with the front passenger side skid plate.
                              Then i removed the passenger front kick panel. First the plastic nut at the front of the kick panel is unscrewed by hand, then the panel needs to be pulled directly back towards you. There are two clips, one near the top at the front of the panel and another near the bottom. Quite a bit of force is required to release the panel from the clips.
                              Bottom Clip at the front of the panel.
                              Top Clip at the front of the panel.
                              His: 1978 FJ45
