Mattfunk's 120
  • Originally posted by Mattfunk 120 View Post
    Yep, my thinking when mounting it was the quickest access when needed, especially if the back was loaded to the ceiling ,but I do agree with Adrian & this will be getting put in the back. Thanks mate .
    Matt
    That is where mine is, but it is a 2.5KG one - even with the quick-fists, still too big of missile to have in the cabin. Mounted on the cargo side of my barrier.
    EDIT - Found my old rig build, here's what I did:
    http://www.pradopoint.com/showthread...ghlight=ryback
    I also have a small ARB one mounted near the back on a quick-fist as well. Seems the original plastic doesn't hold up that well off road!
    • Finally bought some bashplates . I got a great price from Tjm brendale. Very happy with the quality . Nice & solid. I also bought an Amts radiator plate off a mate . A lot more solid than the arb one. 3mm & closes that gap near the tie down points.sorry this is upside down
      So this came off.l
      Rig build here
      • This went on
        Very happy camper!
        Sent from my SM-J110F using Tapatalk
        Mattfunk 120
        Rig build here
        • Looks good Matt.
          • Looking good Matt,
            How heavy are the bash plates?
            Mark
            • Originally posted by Westcoast Mark View Post
              Looking good Matt,
              Mark
              I'm not too sure. They are very solid though. A lot heavier than original
              Rig build here
              • Looks good Matt nice and strong
                2008 Prado GXL D4D Auto Silver, 265/70x17 Mickythompson ATZ 4 ribs, ARB delux Bar Avenger Mako 9500 winch, TJM XGS Gold suspension, Poly airs, Safari Snorkel, Dual Battery system, Voltage Booster, Lightforce XGT lights, GME TX3100 UHF,ARB CKMA12 Compressor, ENZD special quad breather kit,Outback Draw system 1/2 Cargo Barrier,Kaymar duel wheel carrier,AJ120 Sliders, Taipan XP Exhaust, Twin E Lockers, Foxwing, Pioneer Platform.
                • Does the sump plug line up. I've got the ARB plates and love them but the hole for the sump doesn't line up with the the plug. Its a V6 thing I believe.
                  • Originally posted by BiLLz0r View Post
                    Hey mate, yeah both sump & transmission line up with the cutouts. They should have a petrol & diesel version available
                    Matt
                    Rig build here
                    • I had a mate swap out my coils on the weekend . It's been well documented my old coils were cactus after about 11000 km so after 30000km & some other mods on between it was well overdue. Put in Kings HD coils.Feel better so far. We're going to Sundown NP for a long weekend this week so I'm looking forward to seeing how it feels.
                      Matt
                      Rig build here
                      • Sent from my SM-J110F using Tapatalk
                        Rig build here
                        • I got a rear door seal a while ago & went to swap it over a couple of weeks ago but noticed a bit of rust on the bottom of the door fold. This weekend I removed the draws, sanded the rust & hit it with some rust converter then some white over the top. Installed the new seals, draws back in and all done.
                          Rig build here
                          • Originally posted by mattfunk 120 View Post
                            i got a rear door seal a while ago & went to swap it over a couple of weeks ago but noticed a bit of rust on the bottom of the door fold. This weekend i removed the draws, sanded the rust & hit it with some rust converter then some white over the top. Installed the new seals, draws back in and all done.
                            sent from my sm-j110f using tapatalk
                            sand fu*kn sand
