Slipperys 2.8 T/D Kakadu Build
    slipperyskakadu
  • slipperyskakadu
    replied
    Thanks! Yeh piranha Tray. I just waited for them to be released. ARB had some in November last year i think.
    It's a bitch to do properly. Takes alot of time but we'll worth it
    Sent from my SM-G925I using Tapatalk
    Leave a comment:
  • Hally
  • Hally
    replied
    Looks the goods you have done very similar to what i did.
    Where did you get battery tray is it piranhas one? Non were on market when did mine had to make from scratch
    Leave a comment:
  • slipperyskakadu
  • slipperyskakadu
    replied
    Just need to tidy up the wiring and put the insulator plastic sleeve over the engine bay cables and capish. All done! - for the today !
    Leave a comment:
  • slipperyskakadu
  • slipperyskakadu
    replied
    Red Arc Dual Battery SystemIn
    Pulled half the car apart to run 8mm 12v auxiliary to 12 pin socket and the electric brakes signal.
    Also installed two 12v cig auxiliaries for fridge and what ever else.
    Have pulled cables through for future light bar and spotties.
    Hardest part was pulling everything apart with out breaking clips.
    Happy Days
    Leave a comment:
  • slipperyskakadu
  • slipperyskakadu
    replied
    Stinging for more power
    Leave a comment:
  • slipperyskakadu
  • slipperyskakadu
    replied
    Have installed Dobinsons KDSS springs, gave 50mm lift and spaced the rear sensors out 8mm to give an inch in the rear.
    I think i want more in the rear. Not sure yet.
    Just waiting on UHF and some other things to turn up in the post and I'll fit them.
    Matt @ Just Auto's is working on the HKS F-Con ID for the new 2.8TD. So hopefully it will be ready before Birdsville!!!
    Leave a comment:
  • slipperyskakadu
  • slipperyskakadu
    replied
    Ok so i just put dual battery in. Piranha Tray with Supercharge Allrounder MZ70 battery.Click image for larger version
    I've also got 2" lift going in tomorrow. I'll post some photos tomorrow.
    Also just bought.
    Tow Pro Elite Brake Control System
    Uniden UHF with full integrated hand Control
    Cree 140W led Driving lights.
    Red ARC dual Battery System.
    So that'll keep me busy for a couple of days.
    We have a trip planned to Birdsville Big Red Bash in July. Will be doing Dalhousie, Simpson dessert, Sturt Stoney dessert etc... already done some of it the lux i had but i rekon it's going to be so much better in the prado.
    Row
    Leave a comment:
  • slipperyskakadu
  • slipperyskakadu
    replied
    Cheers hodgey,
    I been a bit quiet on here, bought a V8 ute so that has grabbed my attention for the short term. I'm just waiting for winch to go in then I'll hit some tracks.
    I won't be doing much more to the kakadu until March - April.
    Happy 4wdriving
    Leave a comment:
  • bennyhodge
  • bennyhodge
    replied
    Hi Slippery,
    Thanks for sharing
    I decided on the last of the 3.0lt Kakadu and took delivery in July.
    Absolutely love it and will be watching this thread for ideas and inspiration!
    Ours will certainly be hitting the sand dunes and various other 4x4 trails at any chance we get.
    all the best with it
    Hodgey
    Leave a comment:
  • slipperyskakadu
  • slipperyskakadu
    replied
    Originally posted by lst2 View Post
    Hey slips, grats buying Prado.
    Great to see kakadu getting done up. don't see many of them getting done up on road.
    doesn't kakadu come with airbag suspension?
    Cheers ! Yeh it does which makes it a bit harder to get suspension kits. I can get 2 inch lifted bags. Ripping it out and installing coils isn't really an option as it will require modification and a engineers otherwise it technically wouldn't be insured and simply can't have that. I can trick the levelling system to make the rear run higher all the time and throw dobinsons kdss coil overs in the front.
    Leave a comment:
  • Symo
  • Symo
    replied
    Only at the rear, and it's useless for big loads like that bar work. Rip it out and go medium duty 2"
    Leave a comment:
  • lst2
  • lst2
    replied
    Leave a comment:
  • slipperyskakadu
  • slipperyskakadu
    replied
    Next will be winch, dual battery setup and lift. (Still undecided about which way to go with lift)
    Leave a comment:
  • slipperyskakadu
  • slipperyskakadu
    replied
    Some photos of the new gear fitted. Picked it up this afternoon. Very happy. So much goes in to bullbars these days. Relocating front camera, headlight washers, cut outs in step for the sidestep lights.
    I see why ARB are the dearest but the best.
    Leave a comment:
  • slipperyskakadu
  • slipperyskakadu
    replied
    Originally posted by JohnC80 View Post
    Hi mate, nice car. ARB in Qld are telling me that there isn't a battery tray for the 2.8 yet. Did you get a custom one made?
    Hi John, no still waiting. Should be available any day !
    Leave a comment:
