I've finally got around to adding some pics of the engine bay and interior.
The first one is a shot of the engine bay. You can make out the isolator install on the left-hand side and the auxiliary battery on the right (SSB HVT 100 a/h hybrid battery). I have run the cable joining the two batteries along the radiator following the factory wiring loom. At each end is a maxi fuse holder with (I think) a 60 amp fuse. You may also be able to make out the cable coming from the auxiliary positive terminal. This is 6mm wire and goes to a Piranha 4-way fuse box mounted in the jack compartment at the back of the vehicle. Currently I am running the rear cig socket (replaced with a new one) and the merit socket for the fridge, however it gives me the flexibility to be abel to add sockets or powered accessories at a later date without having to rewire things (I'm happy to put up a photo of this if people want). This is fused at the battery by another maxi fuse running a 50 amp fuse.
The second image is a close-up of the isolator (Redarc SBI12) which is super simple and has done a great job. Although you can set this up with a 'linking' function I have avoided it as you need to use much heavier cable. I always have jumper leads with me also so really it avoids over complicating the issue. The alarm is also visible. Anyone know if this is factory (Genuine Toyota) or not? It doesn't work but I was thinking of putting a decent one in there for piece of mind.
The UHF (GME TX3100) is installed where the ashtray used to live. It really is a perfect fit and looks quite neat. From memory I used the mounting screws and holes for the ashtray mount to mount the 3100's bracket, so nothing needed to be drilled. I had the mic mounted to one of the blanks near the antenna height control however on the 3100 the mic is cheap and rattles around a lot over corrugations. If you play with the microphone mounting systems for the higher units you will see that they mount much more firmly. These days I just have it wrapped over the wiper stalk and this works fine.
A shot of the interior, showing the MSA 4x4 canvas seat covers.
The cargo bay, with the wagon liner (specific to the Prado), fridge mounting board with Just Straps Fridge Tie Downs (mounted to the existing holes for the seats) and the merit socket (passenger side just behind the rear seat - flush mount). I have removed all of the hardware for the third row seats to give a bit more room and minimise the chance of damage.
