Gasmans 2010 Kakadu Build
    About 34kg for the full set. minus about 7-10kg for the ones removed. They are 4mm steel.
    [CENTER]Grandpa spec 2010 Kakadu. [/CENTER]
      Okay mate, cheers.
        I have the Kaon ones [ Tin175 on here]. Fit perfectly, weigh 22-23 kg [less the 8 kg you take off]. $430 + postage - $600 to Sydney.Plenty of info on them on here.
          Yeah the KAON ones look good also. I went the Bushskinz as they are made to suit KDSS whereas the KAON ones are not. If you were interested in keeping it light and you have a GXL or less get them for sure(postage looks a bit steep, is that correct)? I am also into moderately heavy bashing so the 4mm plates suited my purpose.
