About 34kg for the full set. minus about 7-10kg for the ones removed. They are 4mm steel.
Gasmans 2010 Kakadu Build
Yeah the KAON ones look good also. I went the Bushskinz as they are made to suit KDSS whereas the KAON ones are not. If you were interested in keeping it light and you have a GXL or less get them for sure(postage looks a bit steep, is that correct)? I am also into moderately heavy bashing so the 4mm plates suited my purpose.[CENTER]Grandpa spec 2010 Kakadu. [/CENTER]
