AJ120s 2009 D4D and DIY camper trailer
This topic is closed.
  • And a few more.
    More playing in the water, this time at Skull Springs
    Camped at Tjingkulatjatjarra Pool
    Hanging Rock, also in Rudall River NP
    Lovely Beach just before reaching Steep Point (Australia's Western most mainland point)
    AJ120
    Out of control poster!
      So here is the Jerry can holder!
      Andrew
      Great work , a couple of thoughts. You may want to make the holes along the lip of the jerry can holder a little larger for the people that want to secure them with wire with eyelets and a padlock. Like on the Kaymar ones.
      Secondly I think a people will have a jerry can with the tap in the bottom, can you insert the jerry can into the holder with the tap in place.? ie in Photo 3? you dont want to have to muck around taking the tap in and out every tiem to remove the jerry can . I guess you could make the silt go all the way to the top if need be.
      Do you have a pic what it looks like with the dual wheel carriers in place?
      Robert
      gumboot
      [B]Robert
      • Originally posted by gumboot View Post
        Andrew
        Robert
        The Jerry can is easily put in and and taken out with the tap attached, also the holes are large enough to add a cable and a modest padlock if desired.
        I haven't taken any pics with the 2 wheels on at this stage, home next week so will get onto that along with a million other things
          Andrew,
          I could not tell from the photos re the tap, the Kaymar holders only come up about half way of the jerry so it is easily seen. Great you have thought of that as well. Nice work.
          Robert
          [B]Robert
          • Great pics AJ! Can't wait for the trip report on your latest adventure.
            • Hi Andrew,
              How did your new rear bar go on the your recent trip? Any feedback?
              Robert
              [B]Robert
                All fitted up and looking the part now!
                Hat Saver fitted so the Akubra now has a home of its own!
                Hi Andrew,
                That looks sensational!
                Can I ask how you've attached it to the roof? Does it use the map and cabin light mounts or does it need to be screwed/attached through the roof carpet?
                Might need a hat keeper myself after fathers day
                Cheers, Leon
                Optix Photographix
                  OK what does it cost? It will vary depending on the excahnge rate at the time and where you live, I was quoted $780AUD for the awning then add another $500+ for air frieght and assorted charges for import brokers and others who sem to do little for their money and you are well into the 4 figure mark,
                  Now available in AU... but at $1495.00 ?? seems a bit excessive
                  http://www.ostrichwingawning.com.au/...ow-to-buy.html
                  Cheers, Leon
                  Optix Photographix
                    Hi Andrew,
                    Robert
                    All went really well with the rear bar, only slight problem which I was aware of is the struts I got aren't quite strong enough when on an angle. I actually ordered new stronger ones but they sent the wrong ones (twice) with the second wrong set only arriving the afternoon before we left so too late to do anything about that. Even then it wasn't really an issue, for the jerry can it was good enough and the spare doesnt hit the door if the strut wont hold it, the tyre just rests on the black plastic around the OE number plate spot.
                    A few early complaints from Trish and Dj regards having to open the 2 carriers each time to access the back, but everyone came to terms with that pretty quickly
                    Originally posted by Snaga View Post
                    Hi Andrew,
                    Come on Snaga, do you really think I would just put a few screws through the hood lining If you look at the picture below you can see one of the mounting brackets at the front (black with 2 holes) I also added a piece of 20 x 20 rhs attached to ribs under where the sunglasses holder was removed from, that bracket bolts to the RHS. Also you can see at the rear a slot in the timber, where the interior light was removed a screwed a braket to the ribs there with a bolt sticking straight down which goes through that slot and just put a large washer and a nut on the inside.
                    It could all be removed and returned to standard and nothing could be seen unless the light or sunglasses holder were removed.
                    It all handled 11,000 kms form our trip with over 5000kms of that being on dirt so pretty happy with it.
                    AJ120
                    • The greatest travesty/injustice of PP is that AJ's build thread/rig is not rated 5 stars...
                      Surely some folks viewing this thread could fix this by giving it a 5 star rating!
                      • Done
                        Cheers, Leon
                        Optix Photographix
                          I would never think such a thing!!
                          Thanks for the info
                          Cheers, Leon
                          Optix Photographix
                          • Seems a couple of votes is all it took!
                            5 stars is the least this rig deserves.
                            • So a few people have been asking me for pictures of the rear bar set up with twin wheel and what it looks like, so here it is.
                              There is enough room between the tyres to go to a 33" tyre if I ever go down that path.
                              And this is all you can see of the tyre in the rear view mirror, not very much at all.
                              AJ120
                              • awesome work Andrew
