Glen's 95 series Prado getting broken in
  • Originally posted by MDST View Post
    That`s a very very good job on both mods!!!!
    Glen, what do you think about this:
    http://toyteclifts.com/index.php?pag...mart&Itemid=72
    Thanks MDST!
    Bolt on protection is fine if you're not going to actually use them on rocks, haha!! But seriously; I was turned off any bolt on products when I saw this:
    http://www.toyota120.com/forum/showthread.php?t=7615
    Also consider the stress which would be applied through the bolt/mount... If it's for mild rocks and dirt it's fine, but my rig is often hoping up big rock steps, so I would break them. A welded on slider like I've used will be much stronger, and worth it in the long run.
    glen_ep
    Addicted PP Member
    • Thanks John,
      I'll check if the welder performed this, otherwise I'll do it myself. I guess it's probably worth doing the entire rig, even though I'm rarely near the coast/salt and always keep the underbody clean.
      • should have maybe looked at longer control arms and moved the whole mount forward to stop some of the "rear steer" at the same time big job but I think it would be worth it! mine rear steers bad under flex!
        75 Series Cruiser No More
        Replaced with a G6E Turbo
        95 Series Prado [url]http://www.pradopoint.com/showthread.php?19936-Beast2h-s-Prado[/url]
        • I did ask Lukey about longer arms, etc, but he pointed out how the arm sits almost horizontal, not downards like big lifted Patrols and Cruisers, so it's not worth it. However, if I ever move ahead with my plans for more rear articulation, I think it might be worth considering again.
          • the idea of longer arms is to allow it to move in less of an ark when off roading it wouldn't make any real difference on road but I think it would make a big difference off road
            • Broke another CV shaft... and this time properly!!!
              Read more about it here:
              http://www.pradopoint.com/showthread...major-recovery!
              glen_ep
              Addicted PP Member
              • We might have to change the tilt of this thread to glens 95 getting broken. Cheers samo
                • Aftermarket or genuine?
                  • LOL @ Samo. I often wanted to change the title to something more sensible but it seems I'm living up to it.
                    Beast,
                    It was a Repco one but after considering the circumstances I'd expect any shaft to fail. Reversing up very steep, all wheels on solid rock, all the weight pushing down on the front, and mostly to the driver side because I was angled that way... The driver side failed.
                    • Holy shit!! I've never seen a broken CV shaft like that.
                      Do you think repco is stronger than toyota? Mmm I don't think so Glen.
                      You have ARB front locker = A stronger diff. Maybe it`s time to go with RCV cv axles ( very expensive ) je je.
                      Prado RZJ90. OME 881 coils Nitrocharger Sport shocks front, 80 Series front coils & rear 80 series Tokico shocks rear, 255/85R16 Cooper Discoverer ST, Viper rocksliders, parking brake cable rear axle bracket, extended rear brake line, extended diff breathers, headers, engine perfomance mods, soon LR upper control arms, ARB rear locker in the future.
                        Hell yeah, it's a serious break isn't it!!!
                        I'm not looking into stronger shafts because I don't want to move the "weakest link" to a different part of the drive line. I can always keep a spare CV shaft in the car, but I cannot bring spare transfer cases or diffs, nor afford to have them rebuilt regularly.
                        • I would've thought that having the front diff lock engaged would be kinder to the CV by reducing the chance of a free spinning front wheel making sudden contact with the ground.
                          • Originally posted by ########## View Post
                            Gee, that's snapped like a carrot there Glen. You might have try Driveline Services Pty. Ltd. and see what they say about your activities when 4wding. I know it's hard but try developing a style of 4wding where you turn the front diff lock on and off and only use the front diff lock when absolutely necessary. If you are not doing this then give it a shot.
                            Just a thought, John (##########).
                            Hey John,
                            LOL, carrot indeed!
                            Actually I do try hard not to use the lockers, especially the front, and do switch them off ASAP. It's much more satisfying getting through an obstical slowly with good lines. Of course that's not always possible, so I typically try with rear only, and then the front if it's not possible.
                            glen_ep
                            Addicted PP Member
                            • Originally posted by Peterpilot View Post
                              In uneven terrain (left vs right) you're absolutely correct! Because there's less chance of sudden impacts.
                              However, in this case all wheels had contact with the ground, there were no impact or sudden movements. The vehicles weight was bearing down on the front axles, and the tyres at 20PSI provided plentiful grip. So whilst the transfer/propshaft/locker would spin, the front tyres didn't want to, and the CV's would have been twisting against the lockers power.
                              • glen_ep
                                Addicted PP Member
