Glen's 95 series Prado getting broken in
  • #76
    As the age old saying goes, Mud Means Money!!
    • #77
      Just read through your build up mate and very impressed you have a unstoppable little monster..looks great up that high with mudders on.
      • #78
        Thanks mate
        glen_ep
        Addicted PP Member
        • #79
          Glen - this is certainly one hell of a 90 series mate. Love the rig and build up.
          Out of curiosity, you said something about seeing the engineer. Was this for 1) the body life; 2) the large tyres; or 3) all of the above? That is, in SA, we are allowed a maximum lift of 50mm which includes all of increased tyre size (max 15mm OD); body lift; and/or suspension lift. is NSW similar in laws? Over here we would have to do a sway test etc to pass anything over 50mm. Just after some info on what exactly you got engineered.
          Ian.
          • #80
            Thanks mate
            A few more pics from the weekend...
            Looking over Tom Groggin Station, VIC:
            Looking towards Mt Anderson, VIC:
            Posing with the Monster Patrol:
            Hope you have rust proofing if you let your rig so close to that foreign thing!
            • #81
              Ian.
              Thanks Ian.
              glen_ep
              Addicted PP Member
              • #82
                Did they have to do a sway test or anything Glen, and was the certificate overly expensive?
                • #83
                  I know it was taken for a test drive, and that it performed very well, but I don't know exactly what tests were performed. Everything was inspected, every single body block, and all measured.
                  Cost was not too much, especially when you consider the money we pour into these vehicles anyway. It's certainly worth it. (PM sent with further detail)
                  • #84
                    Prado has now passed the AUVIS / blue slip inspection! Just need the paperwork filed with RTA and it'll be 100% legal
                    Maybe I should get a custom plate while I'm there? Any suggestions?
                    • #85
                      VZJ95R
                      It doesn't scream the words "Douche bag" and those in the know will get it.
                      • #86
                        Originally posted by williade View Post
                        VZJ95R
                        That's a smart one.
                        I was thinking a little more bullish though.
                        • #87
                          glen_ep
                          Addicted PP Member
                          • #88
                            Have the new ratios returned the gearing to normal or have they over compensated for the tyres?
                            • #89
                              glen_ep
                              Addicted PP Member
                              • #90
                                Hello Glen!!
                                You can honestly say if was worth regear for 255/85 ( 33" ) Tires???
                                This I read before in some important pages:
                                "All new gear sets require a break-in period to prevent damage from overheating. After driving the first 15 or 20 miles you must let the differential cool for 30-40 minutes before proceeding. Drive 500 easy miles before towing. Tow for very short distances (less than 15 miles) and let the differential cool before continuing during the first 45 towing miles. Change the gear oil after the first 500 miles. This will remove any metal particles or phosphorus coating that has come from the new gear set."
                                I think makes perfect sense and it is best to follow this advice. You may already know that je je!
                                Prado RZJ90. OME 881 coils Nitrocharger Sport shocks front, 80 Series front coils & rear 80 series Tokico shocks rear, 255/85R16 Cooper Discoverer ST, Viper rocksliders, parking brake cable rear axle bracket, extended rear brake line, extended diff breathers, headers, engine perfomance mods, soon LR upper control arms, ARB rear locker in the future.
