Originally posted by MidLifeCrisis
View Post
[OT] Jokes page
What role does the donkey play?[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
Originally posted by MidLifeCrisis View Post......Nup, I don't get it.......?[B][SIZE=4]ntp
This is hilarious!!! Remember this the next time you need to return something and they are giving you a hard time!!!!!!!
A woman went to the service counter and told the clerk she wanted a refund for the toaster she bought because it won't work The clerk told her that he can't give her a refund because she bought it on special.
Suddenly, the woman threw her arms up in the air and started screaming,
'PINCH MY NIPPLES,
PINCH MY NIPPLES,
PINCH MY NIPPLES!!!'
The befuddled clerk ran away to get the store manager in front of a growing crowd of customers.
The manager comes to the woman and asks, 'Ma'am what's wrong?'
She explains the problem with the toaster, and he also tells her that he can't give her a refund because she bought it on special.
Once again, the woman throws her arms up in the air and screams,
'PINCH MY NIPPLES,
PINCH MY NIPPLES,
Which begins to draw an even bigger crowd!
In shock, the store manager pleads, 'Ma'am, why are you saying that?'
In a huff, the woman says,
'BECAUSE, I LIKE TO HAVE MY NIPPLES PINCHED WHEN I'M BEING SCREWED !!'
The crowd broke into applause and her money was quickly refunded!!Sold the Prado. Now FJ Cruiser
Originally posted by ntp View PostThat's what the Nun said.
... and the donkey just smiled?[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
TOOLS AND HOW TO USE THEM
SKIL SAW:
A portable cutting tool used to make boards too short.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh shit'.
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
Channel Locks:
Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VYSE- GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for igniting various flammable objects in your shop and creating a fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
Very effective for digit removal !!
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your new brake pads, trapping the jack handle firmly under the bumper.
BAND SAW:
A large stationary power saw primarily used by most shops to cut large pieces into smaller pieces that more easily fit into the trash after you cut on the inside of the line instead of the outside edge. Also good for Digit Removal
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of all the crap you forgot to disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
PVC PIPE CUTTER:
A tool used to make plastic pipe too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door. Works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund cheques, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
SON OF A BITCH TOOL:
Any handy tool that you grab and throw across the garage while yelling 'Son of a bitch' at the top of your lungs. It is also, most often, the next tool that you will need.._,__Sold the Prado. Now FJ Cruiser
Only the Irish have Jokes Like These
Into a Belfast pub comes Paddy Murphy, looking like he'd just
been run over by a train.
His arm is in a sling, his nose is broken, his face is cut and bruised
and he's walking with a limp.
"What happened to you?" asks Sean, the bartender.
" Jamie O'Conner and me had a fight," says Paddy.
" That little twit, O'Conner," says Sean, "He couldn't do that
to you, he must have had something in his hand."
" That he did," says Paddy, "a shovel is what he had, and
a terrible lickin' he gave me with it."
" Well," says Sean, "you should have defended
yourself, didn't you have something in your hand?"
" That I did," said Paddy.
" Mrs. O'Conner's breast, and a thing of beauty
it was, but useless in a fight."
An Irishman who had a little too much to drink is driving
home from the city one night and,
of course, his car is weaving violently all over the road.
A cop pulls him over.
" So," says the cop to the driver, where have ya been?"
"Why, I've been to the pub of course," slurs the drunk.
" Well," says the cop, "it looks like you've had quite
a few to drink this evening."
" I did all right," the drunk says with a smile.
"D id you know," says the cop, standing straight and
folding his arms across his chest,
that a few intersections back, your wife fell out of your car?"
"Oh, thank heavens," sighs the drunk.
"For a minute there, I thought I'd gone deaf."
Brenda O'Malley is home making dinner, as usual,
when Tim Finnegan arrives at her door.
"Brenda, may I come in?" he asks. "I've
somethin' to tell ya".
" Of course you can come in, you're always welcome,
Tim. But where's my husband?"
" That's what I'm here to be telling ya, Brenda."
There was an accident down at the Guinness brewery..."
"Oh, God no!" cries Brenda. "Please don't tell me."
" I must, Brenda. Your husband Shamus is dead
and gone. I'm sorry."
Finally, she looked up at Tim.. "How did it happen, Tim?"
" It was terrible, Brenda. He fell into a vat Of
Guinness Stout and drowned."
"Oh my dear Jesus! But you must tell me the truth,
Tim. Did he at least go quickly?"
"Well, Brenda... no. In fact, he got out three times to pee."
Mary Clancy goes up to Father O' Grady after his Sunday
morning service, and she's in tears.
He says, " So what's bothering you, Mary my dear?"
She says, "Oh, Father, I've got terrible news . My
husband passed away last night."
The priest says, "Oh, Mary, that's terrible. Tell me, Mary,
did he have any last requests?"
S he says, "That he did, Father."
The priest says, "What did he ask, Mary? "
She says, He said, 'Please Mary, put down that damn axe !'
AND THE BEST FOR LAST
A drunk staggers into a Catholic Church, enters
a confessional booth, sits down, but says nothing.
The Priest coughs a few times to get his attention
but the drunk continues to sit there.
Finally, the Priest pounds three times on the wall.
The drunk mumbles, "ain't no use knockin, there's
no paper on this side either!"Sold the Prado. Now FJ Cruiser
I had a dream last night that I was a very studious Chinese student that excelled in the English language.
Guess I was Wong.[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
A very successful attorney parked his brand new Lexus in front of his office, ready to show it off to his colleagues. As he was getting out, a truck came along too closely and completely tore off the driver's door.
Fortunately, a cop in a police car was close enough to see the accident and pulled up behind the Lexus with his lights flashing.
Before the cop had a chance to ask any questions, the attorney started screaming hysterically about how his Lexus, which he had just purchased the day before, was completely ruined and would never be the same, no matter how any car body shop tried to make it new again.
After the lawyer finally wound down from his rant, the cop shook his head in disbelief. "I can't believe how materialistic you lawyers are," he said. "You are so focused on your possessions that you neglect the most important things in life."
"How can you say such a thing?" asked the lawyer.
The cop replied, "Don't you even realize that your left arm is missing? It was severed when the truck hit you!"
"OH, MY GOD!!!" screamed the lawyer.
"My Rolex!!Sold the Prado. Now FJ Cruiser
Blind Bunny, Meet Blind Snake
One morning a blind bunny was hopping down the bunny trail, and he tripped over a large snake and fell, KerPlop!, right on his twitchy little nose. "Oh, please excuse me!" said the bunny. "I didn't mean to trip over you, but I'm blind and can't see."
"That's perfectly all right," replied the snake. "To be sure, it was my fault. I didn't mean to trip you, but I'm blind too, and I didn't see you coming. By the way, what kind of animal are you?"
"Well, I really don't know," said the bunny. "I'm blind, and I've never seen myself. Maybe you could examine me and find out."
So the snake felt the bunny all over, and he said, "Well, you're soft, and cuddly, and you have long silky ears, and a little fluffy tail and a dear twitchy little nose... You must be a bunny rabbit!"
Then he said, "I can't thank you enough, but by the way, what kind of animal are you?"
And the snake replied that he didn't know, and the bunny agreed to examine him, and when he was finished, the snake said, "Well, what kind of an animal am I?"
So the bunny felt the snake all over, and he replied, "You're hard, you're cold, you're slimy and you haven't got any balls... You must be a lawyer."[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
Bloke at a horse race whispers to Paddy next to him,
"Do you want the winner of the next race?"
Paddy replies "No tanks, oi've only got a small yard."
Paddy and Mick found 3 hand grenades and decided to take them to the police station.
Mick "What if one explodes before we get there?"
Paddy: "We'll lie and say we only found two!"
A coach load of paddies on a mystery tour decided to run a sweepstake to guess where they were going.....
the driver won £52!
Paddy finds a sandwich with two wires stickin out of it.
He phones the police and says "Bejasus I've just found a sandwich dat looks like a bomb."
The operator asks, "is it tickin?
Paddy says "No, oi tink it's beef"
Joe says to Paddy: "Close your curtains the next time you're making love to your wife.
The whole street was watching and laughing at you yesterday."
Paddy says: "Well the joke's on them because I wasn't even at home yesterday."
Mick walks into Paddy's barn and catches him dancing naked in front of a tractor.
Mick says, "Oi Paddy, what ya doing?"
Paddy says, "Well me and Mary haven't been getting on in the bedroom lately & the therapist recommended I do something sexy to a tractor."
The Irish have solved their own fuel problems.
They imported 50 million tonnes of sand from the Arabs and they're going to drill for their own oil...
Paddy says to Mick - I'm ready for a holiday, only this year I'm going to do it a bit different.
3 years ago I went to Spain and Mary got pregnant.
2 years ago I went to Italy and Mary got pregnant.
Last year I went to Majorca and Mary got pregnant."
Mick asks - So what are you going to do this year?."
Paddy replies, - I'll take her with me!"
Paddy says to Mick, "Christmas is on a Friday this year"
Mick says "Let's hope it's not the 13th."
Paddy's in the bathroom and Murphy shouts to him. "Did you find the shampoo?"
Paddy says, "Oi did, but it's for dry hair and I've just wet mine."Sold the Prado. Now FJ Cruiser
He was in ecstasy with a huge smile on his face as his wife moved forward, then backwards, forward, then backwards again...... Back and forth... Back and forth..... In and out....... She could feel the sweat on her forehead, between her breasts and trickling down the small of her back. She was getting near to the end. Her heart was pounding..... Her face was flushed..... Then she moaned, softly at first, then began to groan louder. Finally, totally exhausted, she let out an almighty scream and shouted, "Okay, Okay!!! I CAN'T park the bloody Prado!!! You do it, you smug bast**d!!!"2011 Prado 150 SX T/D Auto - Glacier White, with many extras.
My Rig Build Up - [url]http://www.pradopoint.com/showthread.php?21609-Bassett-s-150-SX[/url]
Now living the Dream !!
