Oh great, another trip to Bunnings for a 50c rubber chair leg tip that'll end up being a $100 trip once I get those other 'essentials' that you always come across at Bunnings!
ARB/TJM air compressor & fuel filter bracket for 120/150
Last edited by Hollywood; 14-08-2015, 10:40 PM.[B]2010 GXL Prado D4D Auto[/B] - ARB Deluxe winch bar, Roadsafe recovery points, Rhinorack Pioneer platform, AMTS fuel filter/compressor combo bracket with FM100 filter and ARB compressor, Maxtrax, TIN175 transmission oil cooler bracket and tranny cooler. I'm sure I'll find something else....
Originally posted by Hollywood View PostOh great, another trip to Bunnings for a 50c rubber chair leg tip that'll end up being a $100 trip once I get those other 'essentials' that you always come across at Bunnings!
I put the hose and attachments in the little compartment above the jack compartment in the rear. Not sure if the door will stay closed on a bumpy road as it's not overly secure but we'll see how it goes.[B]2010 GXL Prado D4D Auto[/B] - ARB Deluxe winch bar, Roadsafe recovery points, Rhinorack Pioneer platform, AMTS fuel filter/compressor combo bracket with FM100 filter and ARB compressor, Maxtrax, TIN175 transmission oil cooler bracket and tranny cooler. I'm sure I'll find something else....
Tyre inflater in the funky little compartment above the jack, hose in a 'cloth' shopping back wedged in around the jack.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
My ARB compressor was fitted yesterday.
Today I found the chair leg covers at Bunnings. Thick rubber, 38mm, white for visibility.
I also picked up a little $10 tool bag to keep the hose, gauge and other fittings in, and there's room for a few other items too.
http://www.jamiesonworld.org/images/...8%2010_opt.jpg
http://www.jamiesonworld.org/images/...10_opt%201.jpg
http://www.jamiesonworld.org/images/...10_opt%202.jpgLast edited by GeoffJ; 18-08-2015, 01:51 PM.
Originally posted by maulbeagle View PostHi AMTS,
Have just emailed you some photos from the engine bay of my 2014 GXL V6. Hopefully you can get the ball rolling on a compressor bracket.
Let me know what else you need as well.
Paul
Hi Hollywood, I'm looking at wiring of the pressure switch, did you make your own cable or use the ARB loom, because I just moved my compressor and the ARB loom has an excessive amount of wiring that I don't need.2010 Prado 150 GXL Diesel, Cooper AT3, ARB compressor, Catch Can, Redarc BCDC 1225, Projecta DBC150, Optima YellowTop and RedTop D34, Pioneer Backbone Platform
Originally posted by mullerwh View PostHi Hollywood, I'm looking at wiring of the pressure switch, did you make your own cable or use the ARB loom, because I just moved my compressor and the ARB loom has an excessive amount of wiring that I don't need.
I butchered the ARB loom and used the bits I needed, there's a lot of extra wiring because it's designed for installations where two diff lockers are also installed. I also used some of my own terminals and wire.
In my case the trigger wire for the relay runs from the battery - through the relay - through the rocker switch - through the pressure switch to earth.[B]2010 GXL Prado D4D Auto[/B] - ARB Deluxe winch bar, Roadsafe recovery points, Rhinorack Pioneer platform, AMTS fuel filter/compressor combo bracket with FM100 filter and ARB compressor, Maxtrax, TIN175 transmission oil cooler bracket and tranny cooler. I'm sure I'll find something else....
2008 Prado GXL D4D Auto Silver, 265/70x17 Mickythompson ATZ 4 ribs, ARB delux Bar Avenger Mako 9500 winch, TJM XGS Gold suspension, Poly airs, Safari Snorkel, Dual Battery system, Voltage Booster, Lightforce XGT lights, GME TX3100 UHF,ARB CKMA12 Compressor, ENZD special quad breather kit,Outback Draw system 1/2 Cargo Barrier,Kaymar duel wheel carrier,AJ120 Sliders, Taipan XP Exhaust, Twin E Lockers, Foxwing, Pioneer Platform.
Shouldn't the relay be the last in the connection?[B]2010 GXL Prado D4D Auto[/B] - ARB Deluxe winch bar, Roadsafe recovery points, Rhinorack Pioneer platform, AMTS fuel filter/compressor combo bracket with FM100 filter and ARB compressor, Maxtrax, TIN175 transmission oil cooler bracket and tranny cooler. I'm sure I'll find something else....
