120 Grande rear airbag to coil conversion (AMTS coils)
  • 120 Grande rear airbag to coil conversion (AMTS coils)
    ITEM: 120 Grande rear airbag conversion to coil springs
    CONDITION: New
    REASON FOR SELLING: Leaky rear airbags
    PRICE AND PRICE CONDITIONS: $220 + $20 courier to most metro areas
    EXTRA INFO:
    120ABMD: 40-50mm lift for standard rear weight
    120ABHD: 50mm lift for up to 175kg rear weight
    120ABHHD: 50mm lift for 175 to 300kg rear weight
    email: amtsprado at gmail dot com
    Click image for larger version  Name:	IMG_20160625_144642.jpg Views:	1 Size:	84.7 KB ID:	662023Click image for larger version  Name:	IMG_20160625_144542.jpg Views:	1 Size:	96.6 KB ID:	662024
    Click image for larger version  Name:	IMG_20160418_172104783.jpg Views:	1 Size:	94.8 KB ID:	662025Click image for larger version  Name:	IMG_20160418_172134616.jpg Views:	1 Size:	93.6 KB ID:	662026
    amts
    Ninja Poster.
    Nice work :-)
      Hey amts,
      Very cool stuff, great conversion!
      Looks pretty tidy under there, needs a workout!?
      ...I'm off now to find a Whitey stamp for my 487's, hahaha!
      Best
      Mark
        Very nice indeed.
          Nice colour!
          Well done amts!
            After a year of R&D, I have now converted the rear self-levelling airbags to coils. No further adaptor kits are required.
            These are 120ABMD which gives 40-50mm lift for a standard weight vehicle.
            [ATTACH=CONFIG]24238[/ATTACH] [ATTACH=CONFIG]24239[/ATTACH]
            [ATTACH=CONFIG]24240[/ATTACH] [ATTACH=CONFIG]24241[/ATTACH]
            Very nice indeed. What do you class as a standard weight vehicle? I have a drawer system with 60l fridge in permanently and with drawers loaded up for trips only, so should that warrant a heavier duty spring?
              Originally posted by 1coolbanana View Post
              Nice work
              Hey amts,
              Best
              Mark
              Very nice indeed.
              Thanks fellas!
              Originally posted by photoprado View Post
              Nice colour!
              Well done amts!
              It is to match with a certain other brand of springs
              Standard weight is classed as straight off the showroom floor. You would benefit from the next coil up (120ABHD). It is not as firm as the next one up 120ABHHD.
                Interesting stuff.
                AMTS 120ABMD 420 280 120 Prado Grande rear airbag to coil conversion, 40-50mm lift, standard weight
                AMTS 120ABHD 425 300 120 Prado Grande rear airbag to coil conversion, 40-50mm lift, up to 175kg
                AMTS 120ABHHD 425 330 120 Prado Grande rear airbag to coil conversion, 40-50mm lift, 175kg to 300kg
                Dobinsons C59-325 420 (38.6)220*
                Dobinsons C59-327 410 (47.5)271*
                Dobinsons C59-329 410 (58.3)332*
                Dobinsons C59-397 460 225
                Dobinsons C59-487 430 (49)280
                Dobinsons C59-443V 470 Approx 53-58N/mm at ride height with some constant load
                Dobinsons C59-627 420 270
                So, the Dobinsons 487's are 10mm longer free height and the same rate as your standard weight spring.
                  Can't really compare a Grande and non-Grande models. The geometry is slightly different.
                    So with the conversion kit in, what are the final measurements at the rear now Andrew?
                    Sent from my iPad using Tapatalk Pro
                      At last measurement :
                      120ABMD = 50mm
                      120ABHD = 65mm
                        I meant what is the measurement on your Prado - bottom of rim to guard Andrew...
                          I was at 845mm with the 120ABHD prior to doing an emergency swap.
                            Emergency swap? You mean to ship up north for some unfortunate?
                              Yeah, him.
