120 Recovery Points
  • 120 Recovery Points
    ITEM: Recovery Points for 120 series Prado
    CONDITION: Used but pretty much as new.
    REASON FOR SELLING: Have fitted ARB bar, so had to remove these Recovery Points.
    PRICE AND PRICE CONDITIONS: $45.00 + postage if required.
    EXTRA INFO: Includes High Tensile Bolts, Five months old - used for one recovery (on 4WD course).
    PICTURES:
    Trekrider
    Banned
    What bullbar did you have fitted prior ?? I have the genuine Toyota Soverign bar and I know with this bar I need special recovery hooks due the bar and its design. If you didnt have a bullbar and just had the normal plastic bumper then these wont fit mine Regards Steve
      Steve, he had no bar before. (Its in his thread). These should fit the genuine soverign bar. They are the same design i have on mine, and a lot of others on here. I have a soverign bar, and they fit fine.
      Cheers, Damo
      2005 V6 GXL
        How do they mount as my bar uses one of the holes that these would be used on, I wont get them under/behind the original toyota bullbar bracket and obviously wont go over unless there is some kind of spacer between these recovery hooks and my chassis rail to make up the gap/thickness of the bracket (hope this make sense lol) regards Steve
          Hi Steve,
          As you will have seen, I didn't have a bar fitted before this one so can't comment on the Sovereign Bar but I have heard that others have fitted them using a spacer on the top hole.
            Yeah over the bracket. Enlarge the top hole and reuse the bottom hole.
            You can use a spacer to make up the gap. I didn't, but I mite look at pitting something in there. The gap didnt look to huge, although I haven't had much of a look since the new recall brackets went on.
            Cheers, Damo
            2005 V6 GXL
              there are some threads on recovery points that cover this. search and you may find them, or if you cant use google but add the word pradopoint in with the search. from memory people were using a large washer or similar to space it out
              if these were closer to me and if they fit mine i would jump at them, my issue is a ecb nudge bar that not only uses the same bolts, bar the tubular section of the bar is in the way of the holes for the recovery section of the plates. i may have to look at fitting a custom set that "hangs" a little lower (or get a bullbar if i can win lotto)
              [size=1][color=#990000][b]--> Macarthur District 4WD Club Member <--[/b][/color]
              ::2005 Black Grande Petrol V6::2 x PP Stickers::ARB Deluxe Winch Bar::IPF Spotties + Fogs:: Dual Battery, ABR DBi120 Isolator & Volt Monitor::ARB Portable Air:: Rear Drawer Unit::Trek Table::WAECO 40Lt::WAECO Raps R12U::AMTS Rear Tyre Spacer::HILUX Washers::UHF::Prodigy P3::Stebel Air Horns:: Inverter::CouplerTec Electronic Rustproofing::OEM Roof Racks, Towbar, Hard Wheel Cover::REAR CAMERA to factory GPS::[/size]
                hi Trekrider
                pm sent
                08 D4D White 'Standard' Auto, option pack 2, 2" Dobinsons / Lovells lift
                B.F.G A/T, hilux scoop, pacemaker 3" exhaust,TJM T15 winch bar, TJM snorkle
                  if they were to be posted, how heavy are they with bolts etc, cheers
                    Sorry, this thread has been moved to the sold section as they are sold! If you are asking a general question then they are 1.6kg and it costs $12 to post them.
