ARB Portable Compressor
  • ARB Portable Compressor
    ITEM: ARB Portable Compressor CKMP12
    CONDITION: As new
    REASON FOR SELLING: Would like to purchase one to be mounted under bonnet.
    PRICE AND PRICE CONDITIONS: $250.00 (RRP $349.00 without inflator/deflator)
    EXTRA INFO: Anderson plug fitted to compressor. Supplied long fused cable (with spare fuse) with Anderson plugs both ends. Also original cable has Anderson plug as an option to connect to battery as per original design. I also have included the tyre inflator/deflator
    Features:
    Portable 12V DC air compressor with 6m (20ft) tyre inflation hose
    Class leading flow rate
    Sealed for moisture and dust resistance
    Hard anodised cylinder bore for reduced friction
    Teflon impregnated carbon fibre piston seal for maximum trouble free life
    Anodised mounting bracket dissipates motor heat
    Quality components for quiet operation and extra-long life
    Constructed entirely of lightweight, high strength engineering grade materials
    Over-pressure safety valve equipped
    Motor is internally thermal protected against extreme temperature damage
    Heavy duty maxi-fuse equipped for professional in-line circuit protection
    Conveniently mounted in a durable carry case
    LOCATION: Brisbane South-side. Pick-up Underwood or Freight anywhere at buyers cost.
    PICTURES:
    http://s5.postimage.org/y584lxg9z/IMG_3095.jpg
    http://s5.postimage.org/8npq2byjr/IMG_3097.jpg
    http://s5.postimage.org/k1c9dj92f/IMG_3098.jpg
    http://s5.postimage.org/czebrc5gn/IMG_3099.jpg
    Might be cheaper and easier for you to just remove the ARB compressor from its plastic box and install it under your bonnet??
    Just a thought.
    R
    Ex 1988 Mitsubishi Pajero V6
    Ex 1986 Suzuki Sierra
      Just a thought.
      R
      ARB Coopers plains quoted me approx $170.00 to buy what I need to install under bonnet. This includes a larger tank, harness and brackets that would normally come with the under bonnet unit that would be used for lockers. Bracket I can make up, harness also but not the one for lockers and that's on the wish list.
      This is a fantastic compressor and had thoughts of keeping it as it would be handy to have as a mobile unit as well. It's a good buy for those who don't wish to mount a permanent one.
        I'll take it Hazza... Consider it sold.
        I will PM you this arvo when's get home from work
        Jeff
        [SIZE=3]Jeff[/SIZE]
          Hey Hazza......Just a heads up(??) the only difference between the CKMP12 and the CKMA12 is the latter has a slightly bigger tank, that's it. I'll possibly do a similar install but I'm just going to drill out the rivet pops on my CKMP12 (No Lockers tho)!
            ****sold****
            Thanks for all the advice people - appreciated .
            Now sold to a good PP family.
            Hazza
            Moderators to please move to the Sold section...
            Hazza
