ITEM: ARB Portable Compressor CKMP12
CONDITION: As new
REASON FOR SELLING: Would like to purchase one to be mounted under bonnet.
PRICE AND PRICE CONDITIONS: $250.00 (RRP $349.00 without inflator/deflator)
EXTRA INFO: Anderson plug fitted to compressor. Supplied long fused cable (with spare fuse) with Anderson plugs both ends. Also original cable has Anderson plug as an option to connect to battery as per original design. I also have included the tyre inflator/deflator
Features:
Portable 12V DC air compressor with 6m (20ft) tyre inflation hose
Class leading flow rate
Sealed for moisture and dust resistance
Hard anodised cylinder bore for reduced friction
Teflon impregnated carbon fibre piston seal for maximum trouble free life
Anodised mounting bracket dissipates motor heat
Quality components for quiet operation and extra-long life
Constructed entirely of lightweight, high strength engineering grade materials
Over-pressure safety valve equipped
Motor is internally thermal protected against extreme temperature damage
Heavy duty maxi-fuse equipped for professional in-line circuit protection
Conveniently mounted in a durable carry case
LOCATION: Brisbane South-side. Pick-up Underwood or Freight anywhere at buyers cost.
PICTURES:
http://s5.postimage.org/y584lxg9z/IMG_3095.jpg
http://s5.postimage.org/8npq2byjr/IMG_3097.jpg
http://s5.postimage.org/k1c9dj92f/IMG_3098.jpg
http://s5.postimage.org/czebrc5gn/IMG_3099.jpg
CONDITION: As new
Features:
PICTURES:
