Originally posted by Schlum
View Post
Home made drawers under $110. Basic measurments added
This is a sticky topic.
Originally posted by Gramps View PostWell, finished the drawer yesterday. I'm ready for carpet now but am a bit reluctant to do it myself. I'm really happy with what I've done to this point that I don't want to ruin it with a dodgy final job.
Last photos to be posted when I work out what I'm going to do.[img]http://i49.photobucket.com/albums/f296/1cut808/MUMSRIG/Mitch-Prado.jpg[/img]
Hey,
do you guys reckon that these would handle the drawers I'm planning on building:
http://www.ebay.com.au/itm/Drawer-Sl...item1c1ea5f39d
is 700 too short? What are all of you guys running as runners (pun not intended)Loz - 2007 GXL D4D Auto White
ARB Deluxe Winch Bar, 2" OME Lift, ARB On-Board Air, Safari Snorkel, GME TX3440 UHF, GME AE4018K1 antenna, Redarc/Exide ED5 dual battery system, ARB 47L fridge, Cooper AT3's 265/70/17, LeighW's voltage booster, Lightforce 240XGT's, Outback Solutions Drawer Systems
[url=http://www.pradopoint.com/showthread.php?20863-Loz-s-120-GXL-D4D-Prado&highlight=loz%27s]My Rig Build-Up[/url]
Where did people get their 'T' handles from?04 GXL - Red Centa dual battery, Alloy B/bar, BFG AT's, Rhino Rack commercial bars x 3, GME TX3540, TJM roof cage, Outback Ideas recovery points, LHS rear drawer, 2" Dobinsons/Bilstein lift, ARB CKMA12 air compressor, CoilRite airbags, ARB 2.5m awning, MCC Dual Wheel Carrier, Eagle Eye headlights with 55w hid lo beam.
Got mine at the local caravan shop... $20 each
How much were your runners?Loz - 2007 GXL D4D Auto White
$70 with a load rating of 90 - 100kg's04 GXL - Red Centa dual battery, Alloy B/bar, BFG AT's, Rhino Rack commercial bars x 3, GME TX3540, TJM roof cage, Outback Ideas recovery points, LHS rear drawer, 2" Dobinsons/Bilstein lift, ARB CKMA12 air compressor, CoilRite airbags, ARB 2.5m awning, MCC Dual Wheel Carrier, Eagle Eye headlights with 55w hid lo beam.
Yeah I do, but if you have a look through this thread you'll find Chippy supplied a diagram with measurements early on. I used this to the millimetre.
Carpet for mine this weekend, hopefully I'll be able to find a 'T' handle to finish it off.04 GXL - Red Centa dual battery, Alloy B/bar, BFG AT's, Rhino Rack commercial bars x 3, GME TX3540, TJM roof cage, Outback Ideas recovery points, LHS rear drawer, 2" Dobinsons/Bilstein lift, ARB CKMA12 air compressor, CoilRite airbags, ARB 2.5m awning, MCC Dual Wheel Carrier, Eagle Eye headlights with 55w hid lo beam.
Originally posted by Gramps View PostMy runners are 800mm long, with a drawer length of 860mm. I bought mine from Galvins in SA.
I got my 800 mm runners from Galvins as well and am very happy with them.Justin
2005 120 Series 3.0 TD Auto, OME suspension, Sovereign bullbar, IPF 900XS driving lights, Projecta dual battery system, ARB roof rack, Bridgestone D694 tyres, GME UHF, Custom rear drawer with ARB fridge slide and Waeco 60lt fridge.
http://www.ebay.com.au/itm/RECESSED-...item1c1e3bcb92
Try this link, I think this may be where mine came from.Justin
I'll give it a go, thanks.04 GXL - Red Centa dual battery, Alloy B/bar, BFG AT's, Rhino Rack commercial bars x 3, GME TX3540, TJM roof cage, Outback Ideas recovery points, LHS rear drawer, 2" Dobinsons/Bilstein lift, ARB CKMA12 air compressor, CoilRite airbags, ARB 2.5m awning, MCC Dual Wheel Carrier, Eagle Eye headlights with 55w hid lo beam.
Originally posted by Chippy View Post
Here's the dimensions of the frame unit. The longer base and shorter top allow the middle row seats to still recline.
I've put a small (90 mm) upright in the end of that space to create an extra little storage area in behind the middle row of seats.
Here's the dimensions of the drawer unit itself. There's maybe 1 to 2 mm clearance remaining between the steel runners and the sides of the frame. Its enough to allow the drawer to move freely without rattling around loose.
I hope Chippy doesn't mind, but these are the dimensions I used Ian. Like I said before, I followed them to the mm and they are a perfect fit.04 GXL - Red Centa dual battery, Alloy B/bar, BFG AT's, Rhino Rack commercial bars x 3, GME TX3540, TJM roof cage, Outback Ideas recovery points, LHS rear drawer, 2" Dobinsons/Bilstein lift, ARB CKMA12 air compressor, CoilRite airbags, ARB 2.5m awning, MCC Dual Wheel Carrier, Eagle Eye headlights with 55w hid lo beam.
Hi there, i started doing my drawers and i need some input So i cut the frame using mdf 18mm and started builidng the frame. In the meanwhile i have taken out the 2 plastic parallel strips that host the 4 anchor points, if thats what they are called If you take these out then you can use 8 14mm screws to hold the base in place.
Just wanted to know if that is a good option or might do some sort of damage on the chasis?
Hey pambs,
how did you remove the 4 anchor points? I was thinking of doing something similar, but I don't know how to remove them.
Also, would a 14mm screw rip straight out over a big speed bump? Don't know how thick or thin that metal plate would be (where the anchor points are in).
I was thinking of getting a hose clamp, and tying those around the anchor point for the 3rd row seat and then up and over a cut out in the base of your drawer system... then you can tighten it as much as you can. To remove it, just unscrew that clamp and off you go. You'd put 4 in and I think that that would be extremely sturdy.
Good call or bad call? Anyone tried this?
LozLoz - 2007 GXL D4D Auto White
I used the anchor point bolt holes to mount my drawer and have not had any problems with it moving. I have driven on some pretty rough roads through the Flinders and Gammon ranges with the fridge and fridge slide on top and it hasn't moved.
I would imagine these botl holes need to be quite strong as they would need to hold the weight of the rear seat as well as the passenger in the event of an accident.Justin
